Question about Pioneer DVR-440HX-S DVD Recorder / HDD Recorder
DVR-440HX EPG problems
I have a DVR-440HX. Since the digital switch over the digital epg guide is always incomplete and usually contains a lot of gaps which are random though particularly affects channels 4 and 5. It often makes timer setting impossible. What is causing this can be done to cure it? Also will guide+ ever be back?
Posted by mike_nobbs on
Anonymous
    Sniper:
  • 52 Answers
You could try looking on Pioneer's web site to see if a firmware download is available. This sort of thing can happen as time and technology moves on, a firmware update can be like giving your machine a bit of an upgrade and often rectifies issues like this. As for channel four and 5 doesn't everybodies EPG behave like that? I think it's to do with bandwidth in the digital signal, quite often you will notice that groups of channels will be affected at the same time these usually share the same area of bandwidth.
Regard, James
Posted on Apr 22, 2010
EPG WILL NOT WORK ON PHILIPS 42PFL9703 TV
Philips - Support Forum
www.philips.com/supportforum
PhilipsHere you can discuss all topics related to using Smart TV and Smart TV apps. Also find topics on IP-EPG, HbbTV, MHP, and Google Play store apps on Philips TVs Powered.... First of all JorisM, you're not the only one with this kind of Problem.Missing: 42pfl9703
No EPG data when using WEP EPG ' MediaPortal Forum
forum.team-mediaportal.com > ... > Electronic Program Guide > WebEPG
Jan 1, 2010 - Remote: Microsoft remote. TV: Philips 42pfl9703. TV - HTPC Connection: HDMI Hi, can use some help here. I can not get web EPG to work.
Powerscheduler shuts down PC too early during WEB EPG grabbing ...
Feb 8, 2010 - TV: Philips 42pfl9703 ... I found that data is loaded, but randomlystopped. ... EPG grabbing is busy, but still the system shuts down to early.
DVDR 7250H missing EPG problem - Philips - Digital Spy Forum
Jan 30, 2016 | Philips Televison & Video
How do I access a programme that I have recorded via epg using the original remote control. How do I set the time on my tv.
You don't mention the make and model of the TV, so it's not possible to give a specific answer.
The EPG is normally detailing the TV guide. I wouldn't expect to find my recorded programs listed in the EPG. There'll be a different way of accessing timer recordings. Check your user manual. Same for setting the time. It will be listed in the user manual.
Sep 04, 2014 | Televison & Video
Flashing red cassete light mean
So.... Who uses a VCR any more. They are ancient history.
They don't last forever so perhaps it's time to think ahead....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. I got him a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Cheers
Good Luck
Maybe you can get a little more life out of that VCR still
Aug 15, 2014 | Toshiba W522 4-Head Hi-Fi VCR
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
HDMI Digital Output
Parental Control
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
Can't get EPG to display after set up
johnandja460
You haven't specified which type equipment you are experiencing the problem. With our DISH Network receivers, if the EPG does not display you can do 1 of 2 things. First, unplug the receiver from the electrical outlet for 10 seconds and plug back in. This causes the receiver to reboot and re-acquire satellite signal. Then it will download the EPG.
If you still don't have the EPG, you can then run a check switch test. Press the Menu button on the remote. Main Menu will display on the TV screen. Press 6 (System Setup), 1 (Installation), and 1 (Point Dish) on the number pad. Highlight the Check Switch button on the right of the screen and press select. On the Installation Summary screen, highlight the Test button on the bottom left. Press select. The receiver will perform a switch installation check. After the test is completed, exit out of all screens till you are back to the TV screen. The receiver will acquire satellite signal and download the EPG. I hope this helps.
Ray Calo
DISH Network
Jan 19, 2011 | Sony Televison & Video
My jvc lt32de1bj TV has very slow loading epg. Is there a quick fix to speed it up
I'm afraid not. The loading of EPG programme tames is down to the TV transmissions. Some times you may hit lucky and find the EPG guide straight away, othertimes I have waited 5 minutes for a basic list!
Jan 02, 2011 | JVC Televison & Video
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Nov 17, 2017 | Pinnacle Televison & Video
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Humax pvr 9200T
Hello Fixya Team,
I did solve the problem with the EPG not updating quick enough when you power on.
If once you power on you switch channels to BBC1 youwill find the EPG updates quite quickly.
Hope this helps out.
Lomp.
May 31, 2008 | Humax Televison & Video
Recording from guide plus
Recording from the guide requires that the unit be off to receive guide info regularly and copy it to the HD. If your reception is poor or your DVD on time is too great, the guide will not have any info, and the recording be nameless, except for channel and time info. You can force the EPG mode by removing the power plug from the back of the unit, but only do this after you have turned the unit off! While copying the guide to the HD, the display shows EPG while th unit is off, and you will hear the HD cycling.
Jul 19, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer DVR-440HX-S DVD Recorder / HDD Recorder Logo
269 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
