Canon PowerShot S45 Digital Camera Logo
Question about Canon PowerShot S45 Digital Camera
Powershot s40 drivers for windows 7
Canon powershot s40 drivers for windows 7
Posted by artend on
Anonymous
    President:
  • 1,194 Answers
There in no need to download driver explicitly, As driver comes inbuilt with your Window 7 operating system, you need to connect your device (Camera) with the computer through data cable and just need to follow the instructions.
For more information visit this link
Have a nice day
Rating the solution is highly appreciated.
Posted on Apr 20, 2010
2answers
I have a Canon PowerShot A20, but I can't find the W7 driver . Could you help me ? Regards rene
There is no Windows 7 Driver available for this model.
Your computer should still pick it up as an external drive in Windows Explorer so you should still be able to copy your photos to your hard drive from their.
Powershot A470. used to be able to download pics with no prob to my computer. Got a new pc Samsung with windows 7 (RV510) but for some reason it cant download to my old pc either.. just seems its not...
Windows7 usually use x64 bit system operation, drivers which run in windows XP or Vista can be uninstallable in Windows 7 because XP and Vista use x32 bit system operation (except certain series).
See your OS from Device Manager (Windows+PauseBreak > Device Manager), 32 bit or 64 bit. Then you can download the driver compatible with your OS from here :
http://driverscollection.com/?H=PowerShot%20A470&By=Canon
If this useful, RATE please !
1helpful
I recently got new computer with Windows 7 Professional. My Canon PowerShot SD790 IS will not connect to computer. I have removed all the Canon files and reinstalled the Digital Camera Solution Disk 33.0...
You are going to have to download a Windows 7 driver from Canon that will allow them to communicate.
Go to this page here (click here) and under the Drivers and Software, where it says "Choose your operating system", select Windows 7.
1helpful
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
2answers
My Window 7 can not detect my PowerShot SD800 IS from USB. I can not using Canon software detect camera
Thanks for contacting FixYa Technical Support.
I am not sure if you have attempted to run Canon's most current driver update for the Canon PowerShot SD800 IS, but here is the link for that driver.
Canon PowerShot SD800 IS Drivers for Windows 7
This driver is for Windows 7, 32 bit and 64 bit systems.
What you may want to try first, is to disconnect your camera from your PC, install this driver update and then connect the PowerShot and see if it will detect it.
Driver updates are usually the first steps to take in troubleshooting device connection issues with PCs.
Hope this helps!
Regards,
-Mactechtrainer
A80 Windows 7 driver
Use a card reader instead of your camera.
2helpful
Cannot download pictures on laptop with windows 7
1. You might be facing compatibility problems with Windows 7 OS as the new patches or updates for it are still awaited!
2. Try to download the Canon Powershot Software from these sites :
http://software.canon-europe.com/products/0010333.asp
http://driverscollection.com/?H=PowerShot%20A530&By=Canon
please rate this advice if it helps....tc! :)
Blank screen on Powershot S40 - I don't think it's E18
This is a problem with the CCD card. Canon has issued a recall and will fix/repair for free. Go to the Canon website and search for CCD to get more info (or call them direct).
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
