Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
4 Gb pen drive can't poen
I have 4 GB sandisk pendrive when I am connecting to pc then he detected but can't open.and massage appear formet the pen drive but my IMP file in this pen drive please suggest me solution how can i open this pen drive?
    New Friend:
  • 42 Answers
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
Posted on Apr 20, 2010
I cannot format my 16 gb pendrive is show unable to format the pendrive
i cannot open or format my 16gb transend pendrive ...when i tries to open a message appeares " please inset a disc into drive "........plz help me..
Oct 27, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Tip
Use Your Pen Drive as Ram 1) Connect your pen drive to your PC [pen drive should...
1) Connect your pen drive to your PC [pen drive should be at least 1 GB or if you having 4 GB then its better]
2) Allow PC what he is supposed to do,let system to detect pen drive.
3) After your PC finished with its detection work,you have to do some little
4) Right click on the My Computer and select the properties
5) Goto advanced and then performance setting then advanced then
6) Select pen drive and click on custom size " Check the value of space available "
7) Enter the same in the Initial and the Max columns
" You just used the memory of the PenDrive as a Virtual Memory "
8) Now restart your pc and enjoy your fast and super system
010100101 G.I.G hacker 010100101
www.gighacker.blogspot.com
on Feb 12, 2010 | Computers & Internet
My kingston 8gb and 4gb pendrive when connect to my computer massage appear "disk is write protected" how to solve describe me with full detail
If your pc has virus or your pen drive have some virus u get these problems just try to plug in another pc and try to format..
Aug 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
4 GB sandisk pendrive can't open
1. continue without solving
2. If you didn't remove the drive with the safe removal tool in the task bar ( lower right hand corner) the drive will lose it's ability to be mounted or seen by Windows and will not format. You will lose data.
Apr 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk 4gb pendrive not working
Best thing to do is format the drive. Dont go for a quick format
Jun 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pen Drive Driver
You must install a "Driver" for it to work under Win98, go to the manufacturers web site and download the driver and install.
Feb 07, 2008 | SanDisk 8GB microSDHC Memory Card with...
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
147 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
