I opened my printer to change the ink and now it says the cover is open and is frozen. we have unplugged and tried to reset but it continues to say cover open. Any clue?
Remove the cartridges from the printer, then close the covers. Unplug the printer from the power source. Plug it back in after 10-15 seconds. Check if "cover is open" message is still coming up on the display. If yes, the cover sensor may have gotten stuck when you opened the printer to change the cartridges. Try to exercise the lever to release the tension. If problem persists, I advise you to call Lexmark. If not, proceed on reloading the cartridges. Close the covers. Let it print the alignment page all the way through without cancelling it. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Sometimes
the ink cartridge carrier won't automatically move to its loading position even
when the printer is on and the cover is open. Follow the steps below:
1.
2.
With the cover open, hold the solid white strip that connects from the carrier
assembly to the ink cartridge carrier and gently slide the cartridge carrier to
the center of the printer.
3.
Remove the used cartridges.
4.
Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Sometimes
1.
2.
3.
4.
5.
I hope this information has been helpful.
Sometimes the ink
cartridge carrier won't automatically move to its loading position even when
1. Unplug the
2. With the cover
open, hold the solid white strip that connects from the carrier assembly to the
ink cartridge carrier and gently slide the cartridge carrier to the center of
the printer.
3. Remove the
used cartridges.
4. Load the new
