Question about Hitachi 168589 DVD Player/VCR
Hooking up to a sony tv need to know were the wires go and is there any set ups to be done
  • 11,896 Answers
Cables go from dvd player/vcr OUTPUTS to tv's INPUTS,
Then turn tv to Input or AV channel and you should be good.
Posted on Apr 19, 2010
6ya staff
SOURCE:
How to hook up lvds wires in Sony KF-50we610 T.V. Picture would be nice. Please help!! TY
Hello, here's a link to a video on how to pull apart and put together your set. This should help, let me know if you need further assistance: https://www.youtube.com/watch?v=RgZz9peR-ro
Sep 17, 2014 | Sony KF-50WE610
How to hook up sony se501 speakers?
Good day Virgil. Please be a bit more specific. Are you using a Decoder to receive the TV signal? When you say " hook speaker wires to the TV" - do you mean via the Sony SE501 receiver??Just tell me what components you have and I can help you.
Sep 09, 2012 | Sony Str-Se501 Stereo Receivers
How do i hook up an antenna to a samsung tv model no. cxj1952
If the set only has a coax cable fitting and you have a antenna with flat wire--you need the adapter that takes the flat wire and slides onto the coax fitting.
Once done in the menu you have to set the set to cable and operate the auto program etc.
May 28, 2012 | Samsung CXJ1952 19 in. Combo
I had my playstion 3 hooked up to an hd tv and then i hooked it up to a regular tv..the tv isnt reconizing the playstation at alll..i dont know what to do,
Hook the ps3 back up to the hd tv. From here you need to acces the settings resolution options. Set the resolution to 480 (standard tv). Once set for standard, turn off, disconnect, and set up to non hd tv. Problem solved.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
HOW DO YOU HOOK UP A PLAYSTATION 3 TO THE INTERNET
It can be done via a wired and a wireless connection. For the wired connection, you just need to hook the ethernet cable at the ethernet port on your PS3. For the wireless connection, you just need to set it up under the Network Connections on your System Settings for the PS3.
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
It's hooked up with HDMI,but all of a sudden can't get any picture. i can hear the sound. No luck when i hooked it up with rca wires either.
Check your connections to the TV itself to make sure they are properly hooked up. Once this is done, turn off your PS3 completely. Turn the PS3 back on using the touch button on the front, BUT keep your finger on the button until you see something on your screen. This will reset your video settings back to 480i which will work on any tv/monitor and should allow it to auto detect the HDMI option again.
If this doesn't work, you may want to make sure that your HDMI/AV/COMPOSITE settings and inputs are working correctly on your tv. You might want to try and plug something else in for full testing purposes if the above does not fix your issue.
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
How to connect all components to work
you will have all them all in user manual itself right?
Jun 08, 2008 | Audio Players & Recorders
Dvd movies
sounds like you have hooked up your system with a component cable these must be wired red 2red green2green blue2blue and this output set on your system and selected on your tv.if you have done this and your cables are ok you may have a fault in your system or tv.
hope this is helpful.
cable guy.
Jun 05, 2008 | Sony DAV-DX375 System
SONY TV FROM FLORIDA
We hooked it up with another DVD player, no difference, We used another TV, worked good. We changed all the cable cords, and made no difference. It comes right down to that TV. yes from aboe it is 100% sure that trouble is in tv. every channel is blury and has a trail. it is due to focus of your tv is not ok 1 adjust focus control 2 focur wire going to crt base might be loose due to some foreign material deposited on crt base. 3 defective crt base. 4 if tv is old there might be possibility of crt getting weak. hope this will help.
Oct 07, 2007 | Sony KV-32XBR450 32" TV
Hitachi 168589 DVD Player/VCR Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
