Cars & Trucks Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear the error codes on a 2001 Dodge Ram 3500 diesel?
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Apr 19, 2010
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737672
Points
36075
You will need a hand-held obd2 scanner to clear the codes. Advanced Auto store will do it for free if you have one in your area. Other part stores will also do it for free.
You can disconnect the negative battery cable for 10 minutes and replace it, but it doesn't always work. Sometimes the codes are stored in memory and require the hand-held obd2 to clear them
1helpful
2answers
What is the engine power of the Dodge RAM 3500 from the year 2001?
HD 5.9L (360) SMPI V8 "MAGNUM"
Horsepower: 245 @ 4000 RPM
Torque: 345 @ 3200
5.9L (359) HO I6 CUMMINS TURBO DIESEL
Horsepower: 245 @ 2700 RPM
Torque: 505 @ 1600 - 2700 RPM
I'm getting a F707B and F707A (APS Relay - Contall circuit open) error code on Dodge Ram diesel. Any idea what could this be? Truck runs great - just the AC on passanger side does not work as well as on...
sounds like a wire is disconnected somewhere, check for melted wires, or one that has a lot of grit or corrosion on it. Use a good electrical cleaner. Clear codes and retry your diagnostics test.
2001 dodge ram 3500 no dashboard, running lights, backup or tail lights
Check the headlight switch. The power goes from the fuse to the headlight switch and then to the dash and running lights.
1helpful
Cummins diesel in 2001 Dodge is cutting out and mild surge. code#s are P0500,P0370 P1693
you have codes related to the pcm, transfer pump and a vehicle speed sensor. these could be related or all individual issues. related issued could be wiring, untill you start doing testing it will be hard to tell.
start cheap and test the speed sensor first, then you can clear the codes and continue on any codes come back.
Disconnect the PCM harness connector(s).
Disconnect the Vehicle Speed Sensor harness connector.
Note: Check connectors - Clean/repair as necessary.
Measure the resistance of the 5 Volt Supply circuit between the VSS harness
connector and the PCM harness connector.
Is the resistance above 5.0 ohms?
2helpful
2001 dodge ram 2500 4x4 diesel code p0236
the code is map sensor too high, too long. certain programmers with boost foolers can cause this. if running a programmer disconnect and if problem isnt fixed replace the map sensor.
3helpful
Where is the cam shaft position sensor on a 2001 dodge ram 3500 diesel?
it is in the rear of the timing cover, below the injection pump and above the vacuum pump. hope this helps!!
2001 Dodge Ram, 3500, CTD 5.9, AT, 2WD, No Bus
No bus error code has nothing to do with your fuse panel this is a ECM /ECU error code... sorry but get ready to spend some money for a new ECM
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
