SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
SOURCE: the oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
SOURCE: i manually locked my oven
Nice to know that your oven is now working. Thank you for using fixya!
• The F5 error code indicates that the oven sensor has changed its resistance value and has failed to read the oven temperature correctly.
• If you choose the repair the range yourself it is fairly easy to do.
• REMOVE POWER to the range and then open oven door and locate the pencil like probe protruding from the back of the oven cavity near the ceiling.
• Locate and remove the screws that are holding the sensor to the oven liner.
• Carefully remove the sensor and connecting wire harness to the point were you can get to the connector. Install new sensor and re-install into oven liner.
• Note!(some sensors have a harness plug and some have ceramic wire connectors).
