Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
I bridge my amp to two sony xplode ten inch speakers and the amp cuts in amd out why ?
Posted by rossjennifer on
  • Anonymous May 11, 2010
    what are the specs on the amp? total wattage output when bridged and at what ohm load? What ohm rating is each speaker. Your problem has to do with what the amp is capable of at a certain total ohm load. Too low of total ohm load will make the amp work harder. Too high of total ohm load will make the amp put out less wattage. And usually when an amp is used in bridged mode, 1 speaker per amp is best.
Anonymous
    New Friend:
    Problem Solver:
  • 10 Answers
Your amp is to weak for the sub's
Posted on Apr 27, 2010
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sony XPlode Amp XM-2150GSX, whats setoff sensor mean? Amp keeps cutting out!
you have a short or your over heating. or more lkely bad ground or you bridged your subs and you should not have that what will give you those erros. OH most common tho is the remote cable from the cd player is loose or the rca cables are loose.
I hooked up 1 10" type r to my 600w sony xplode
How many ohms is the speaker? You have the amp bridged going into the sub? You have the negative of one side hooked up to the negative and the positive on the other side hooked up to the positive?
It says that it is bridgable at 4 ohms. What about the input? Set your stereo about half way up. Then turn your amps gain up slowly until it is where you want to listen to it normally. Not to loud. Then when you turn it up it isn't too much.
But it sounds like you have way too much power for one speaker. Especially a ten. It takes two tens to equal one 12.
How do u know if A sony xplode XM-552ZR amp is on and how do u connect it to a sony xplode cdx-gt570 head unit.
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
MTX Thunder series 7402 Amp cutting out at Hard pound.
Most likely the ohm load is too low, if you have the subs wired in parallel rewire them in series and see if that resolves the problem. if not then you do not have enough battery power to support the draw that the amplifier pulls. if the vehicles voltage drops below 11.5 volts the amplifier will momentarily shut off, similar to how the lights in your house dim when the a/c cuts on due to the sudden power draw. hope this helps. p.s. if you cant afford another battery right away, lowering the crossover frequency to around 65hz will greatly reduce the amount of current necessary to keep the amp pumping. (in my opinion it sound better that way anyhow.)
1helpful
Will a sony xplode 100w amp bridged push a 1600w cab? if not what is the best compatible cabinet wattage reccomedation?
100watt amp and 1600 watt cab?? Your amp will run it but a lot of the dynnamics of the speakers won't be there.
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
1helpful
6answers
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
2helpful
2answers
Sony Xplod 1000 watt car amp quit working.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Top Sony Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
