Question about Motorola CLS 1410 (4 Channels) 2-Way Radio
How to change frequency on the cls 1410 - Motorola CLS 1410 (4 Channels) 2-Way Radio
Posted by jlegorreta on
eradiostore
  • Motorola Master
  • 1,667 Answers
Here is a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find basic programming instructions on page 28.
Best regards.
Posted on Apr 19, 2010
3 Related Answers
eradiostore
eradiostore
  • 1667 Answers
SOURCE: How do you set the channel and frequency for the
Here is a link to the manual: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find programming information on page 28.
Best regards.
Posted on May 05, 2010
eradiostore
eradiostore
  • 1667 Answers
SOURCE: When I tried to change the frequency on my
To unlock (or lock) your keypad hold the menu button in for 3 seconds.
Here is a link to the user guide. The CLS1110 is a 1 channel radio. It has several frequencies built in to choose from.
Posted on Dec 08, 2009
Testimonial: "Oh my gosh, that was so easy. Thank you."
eradiostore
eradiostore
  • 1667 Answers
SOURCE: Can a Motorola CLS 1410 4 channel can be
Yes. Put the radio in programming mode and walk though the programming steps. The Privacy Tone is referred to as CODE in the manual. Here is a link to the manual http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf. Programming instructions begin on page 28.
Best regards.
Posted on Oct 29, 2011
Motorola cls 1410 on frequency 10 and need it to bw on 2
The manual can be found at:
http://www.axcesstechnologysource.com/manuals/cls_series_userguide.pdf
If you need replacements including a CLS replacement antenna, this place is great:
http://shopwiscomm.com/Motorola-CLS1110-CLS1410-C254041.aspx?sid=2181
2answers
How do you reset Motorola CLS 1410
The radio has fixed frequencies. If you wish to remove the options, they must be done individually for each channel. Here is a link to the manual: http://www.motorolasolutions.com/web/Business/Products/Two-way%20Radios/Portable%20Radios/CLS_Series_Radios/CLS%20Series%20User%20Guide.pdf
What are the frequencies for a motorola cls 1410 radio
Here's a link to the user guide for the CLS model radios. You will find the frequency list on pages 39-41.
Best regards.
Can a Motorola CLS 1410 4 channel can be programmed that all 4 channels have the same operating frequency but different privacy tone on each different channel?
Best regards.
2answers
I need the repair manual for motorola cls 1410
Sorry to say, there is no repair manual available for the CLS1410, nor are parts available, other than a few parts common to other radios. If you use the Motorola Repair Depot, they will replace your radio for the price of the repair (currently $116)
Best regards.
We are having problems with one of our radios. It turns on but we can't hear when someone speaks or they can't hear when I speak. We are on the same channel but the frequency is different and the code is...
You will find programming instructions beginning on page 28. Or you can restore the factory settings, turn the radio on while holding Push to Talk and Menu button for 3 seconds.
Vibra call is described on page 30.
Best regards.
Can not change code and frequency
First, we would suggest resetting the radio to the factory default settings by turning the radio on while holding Push to Talk and Menu button for 3 seconds.
After doing this, check to see your radios function with one another. If they do, then proceed to programming the radio to the frequency/PL codes you are wanting. If the radios do not communicate after resetting them, one of the radios has a problem.
Here is a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find programming instructions on page 28, with a frequency chart located on page 26.
Best regards.
2helpful
When I tried to change the frequency on my Motorola CLS 1110, I see a lock graphic. How can I get rid of the lock so I can change the frequency. Right now it has only 1 and 2 frequency and I need 4. Thank...
Motorola CLS 1410 (4 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
