'unknown disc error' problem on LG VHS-DVD combos and DVD burners
Refering to the 'unknown disc error' problem on ALL LG DVD reader/recorders, can anyone confirm this:
Assuming that:
- An LG DVD reader/recorder 'remembers' the position the last DVD read, was at, when the machine was stopped/switched off, to continue there next time it is switched on.
- A problem occurs after/during or while burning onto a RW-DVD: You remove the DVD and switch off the unit.
- What does the machine remember?
- It WILL say 'unknown disc, please check disk again' next time you will try and play ANY other burned or purchased DVD.
LG's DVD burners all seem to have a software problem linked to illogical thinking of the software programmer.
No one at LG knows how to 'reset' a unit, i.e. to get the unit to 'forget' a faulty burn... which is the origin of the 'unknown disc' error. Logically to the machine, any other DVD put in AFTER a burning problem is an 'unknown disc'...
Posted by rraphaelj on
savageinjun
    Scholar:
  • 109 Answers
Haha...your kidding right..
Posted on Apr 19, 2010
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
1,430 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
