Panasonic VDR-D300 DVD Camcorder Logo
Anonymous Posted on Apr 19, 2010
I am using a DVD-RW disc inside my panasonic VDR -D160 for my video recordings. When I try to copy CD contents onto my PC (Windows XP Professional), it is not possible to read directly the CD from the drive of my computer. i dont know how to transfer video from CD-RW i used to my computer before editing, it si any software using to transfer? if the case, where should i download it?
Anonymous
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Apr 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
17356
Points
125
Dont you have to finalise the disc?
1helpful
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Please i have a problem, i can't read video from my camcorder directely when introduicing CD RW in my computer. i have a panasonic VDR-D160 and its not possible to transfer diveo to edite film. how to do,...
Hi!
The driver for this device can be download from the link below
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/DVD-Camcorders/Drivers-Downloads/model.VDR-D300.D#ts
click the link. download the driver and the instruction manual.
Install the driver on your pc. You can try this driver on windows 98, nt, 2000 and xp. But this driver is specifically designed for windows vista.
I hope this works for you.
Post back if you still have questions.
mace
I lost the software after fromating my laptop I need to instal the same again but I don't have the disc. Can you please assist. Here is my Camera details: Panasonic VDR-D160 30x Optical...
Type on Google Exemple: Download Palmcorder VDR-M30 DVD drivers for XP or For the windows you use in your Laptop Check Also Under Panasonic.com But it May Cost Something ...Google it better
7helpful
3answers
How do I format a disc (DVD or CD) on Windows XP?
You only format a CD/RW or a DVD/RW, which are re-writeable.
Regular discs do not need to be formatted (CD-R or DVD+R, DVD-R, DVD+R DL, etc.).
To format the DVD/RW idisc, use the "burner" software ( Sonic?, Nero?) and choose [Tools] [Erase Disc] (erase is the same as format)
2answers
INCOMPATIBLE DISC
Good news.. you should be able to put the disc back in to the device that you recorded in on... and go to the menu to do the finalize... in fact, you may be able to add more to you disc prior to the finalize process if you want...
once it's finalized you should be able to view on other equipment... your files should all be there as well.
Let me know how you do!
11helpful
4answers
I have a Panasonic VDR-D160 mini disc camcorder. Im unable to edit discs while in camera and cannot connect camera to my computer. Computer doesnt recognize hardware, manaul is no assistance. No usb or...
i have recored the sveral movie on the DVD-R disc using Panasonic VDR-D160 and then i take the DVD-R disc with me to leave for another country (the Panasonic VDR-D160 left at home) and now i can not read the moviesrecored on the DVD-R disc !!! Why this should be ? The computer view the empty disc although it contains several movies when i checked it from Panasonic VDR-D160 camera when i was at home ! How can i do now to read the movies from the disc ? Thanks a lot !
6helpful
3answers
VDR M50 drivers for Windows Vista Ultimate
plug the camera in via usb so the camera shows up as a removeable drive. if it picks up the camera as a DVD burner instead of drive, install the DVD-RAM drivers (in compatibility mode for XP SP2 w/ administrative privileges if necessary) and browse the contents of the disc - copy and paste the VRO file to your hard drive and rename it as an mpg - should be readable at that point. good luck.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
