You do this by logging onto the router with a browser, and setting the channel in Wireless transmitter settings.
You need to use your manual to do this.
You need to login into the admin console of the router using Admin login credentials. Once in the console you can go to wireless settings and chage the broadcasting channel.
Please rate if helpful.
Thanks
SOURCE: how to change channel
Log in to your router. Select Wireless Setting then Basic Security Settings. Item #3 is the channel. Select the channel you want, then select Apply at the bottom of the page, et voila, you'll have your new channel. Good luck getting a better S/N ratio.
or follow this link
wordnet.princeton.edu/perl/webwn?s=tune
