Question about Alpine CTA-1505
Bass aint working how to turn on menu features with out remote control
Posted by jaypina on
DJ Etamin
    New Friend:
Press and hold the INTLZ button for at
least
3 seconds.
Notes:
Initial mode is "SUBW OFF."
Set to "SUBW OFF" unless the
subwoofer is used.
When the subwoofer is turned on, the
subwoofer output level can be adjusted.
For more details, refer to the Adjusting
Volume/Balance/Fader
hope this solves youre problem found it in the manual.
Posted on Jan 20, 2013
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
Controls not working onDaytek TV, 40 in LCD,
yes, look carefully in the manual as I think it has a lock out feature that will lock out both keyboard on set and remote except for on off features.
Jun 13, 2012 | Televison & Video
Any one got the universal remote code for a sony bravia KDL-32S3000. Trying to reprogramme my sky HD remote and it will not work the TVguide button.
The Universal Remote can be used for the basic operations like turning ON/OFF, changing the channels, changing the volume. However, the main features like TV Guide and internal menu settings cannot be accessed using the Universal Remote. To access the all features of the product, it is required to use the Remote supplied with that product only.
Nov 22, 2010 | Universal Remote Control Remote Control
How do you get the bass remote to work, when i plug it in i still cant control the bass
the remote wire is just to turn the amp on and off. it doesn't really turn the bass up or down.
Aug 10, 2009 | Pyramid PB1281X Car Audio Amplifier
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
I have a mtx x1000d and i cant get the remote bass to work
These units usually are "smart", as when you are all the way down the received input is too low to activate the control and when you are all the way up it is protecting the amp and your ears.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
Bass knob/remote for kac-9152d
dont try that yet,doesnt require remote to work,only added feature
Aug 11, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Cannot turn the menu feature on with RCA remote control.
You will need an original remote,Very few times a universal remote will cover menu features ,but most satelite reciever remotes will
Nov 09, 2006 | Mitsubishi CK-31304 TV
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
