Cars & Trucks Logo
Posted on Apr 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1966 ford f100 inline 6 cyl 300\r\engine turns
1966 ford f100 inline 6 cyl 300 engine turns over but will not fire. I replaced coil,plugs and wires,rotor button and points and still will not fire. I am getting power to the coil. its also getting fuel.
Anonymous
Level 3:
President:
  • Master 834 Answers
  • Posted on Apr 19, 2010
Anonymous
Master
Level 3:
President:
Answers
834
Questions
0
Helped
899451
Points
3735
Make sure that the primary wire between the distributor ignition points and ignition coil is not damaged anywhere and grounding the circuit out. This is not a ground wire.
Replace the ignition points condenser, if this is shorted your points will never be able to work. With the condenser removed, use an ohm meter to check the resistance between the end of the condenser wire and the condenser caseing, there should be infinite resistance or an open loop, but it should not show any kind of a connection between the two, or it is grounded or "shorted to ground" and it will prevent the ignition system from working.
Are the ignition points adjusted properly? They have to open and close to send a dwell signal to the coil.
Connect a test light to ground and on the NEG. (-) side of the coil, have someone crank the engine and look for the test light to flash, the test light should flash indicating a dwell signal or coil pulse. (Do not use the POS. + side of the coil for this test, because you will not get a dwell signal).
If no dwell signal, then...
1. Turn off ignition and remove the distributor cap and turn the engine over until a high spot on the distributor cam lobe is on the rubbing block on the ignition points.
This is the fully open position for the ignition points and where they need to be to set them. and if you do not know the feeler gauge size, or the dwell angle to set your points at (according to manufacturers specifications), then tear off a piece of a match book and place it between the two point breakers.
2. Loosen the point hold down adjusting screw and move the base of the points with a screwdriver (look for adjusting nothches), until there is a light drag felt pulling on the match book. For the newer GM's up to 1974, just use a 1/8 allen wrench to obtain the same light drag on the match book.
3. Remove the matchbook and there should still be a small gap between the point breakers, rotate the engine and you should see the points open and fully close.
4. Pull the coil wire out of the distributor cap and ground the end of the coil wire well or you might get shocked.
5. Have someone crank the engine and re-check for a dwell signal, you should also see a blue-white spark flashing between the point breakers as they open and close.
If you now have a dwell signal then replace the distributor cap back onto the distributor and the the coil wire back onto the distributor cap, the engine should now start.
If you did not grease the rubbing block of the ignition points with die-electric grease when you installed them, then the rubbing block on the points will wear down prematurely, the points will close down, and the engine will no longer start.
If you crank your engine over and the ignition rotor turns clockwise (looking down at the rotor) then you need to put the die-electric grease along the right side of the rubbing block edge (looking down at the points) so that the grease is trapped between the points and the distributor cam lobe, and the distributor cam lobe can pick up the grease. (Grease the left side of the rubbing block edge if the ignition rotor turns counter-clockwise). Only use die-electric grease.
How do I fix my 1995 Ford F 150 XLT 300 CI.Inline 6 Cyl that cranks over but,will not start ?
Sounds like a grounding issue , check all hard frame grounds , try grounding the coil to batt
1966 Ford F100 transmission swap
you need a flywheel that in balanced with the 300
2helpful
Need firing order diagram for 1995 f-150 6-cyl 4.9 litre
1-5-3-6-2-4 is the spark plug firing order for the 4.9 L ( 300 cubic inch ) straight 6
The distributor rotor turns CLOCKWISE
The marked # 1 position on the distributor cap is installed facing away from the engine
Hope this helps
1helpful
2answers
I need a diagram for the spark plug wiring on a 1980 F100 6 cyl
Hello kat801931,
The firing order is:
1 5 3 6 2 4
Below is a picture of the cylinder order and the distributor. Number 1 cylinder is at the "white" location on the distributor. Good luck.
Regards,
netvan
1helpful
2answers
2000 ford mustang code 453 and missfire cyl 5 where is the cyl
a haynes manual from a parts place will show you--or chec the condition of each plug wire-if one looks bad or falls apart--probly need to get all new wires /plugs
4helpful
89 FORD F-150 ENGINE IS TURNING OVER GETTING GAS REPLACED THE COIL STILL WANT START WHERE IS THE MODULE LOCATED HOPE ITS NOT THE TIMING ALMOST FORGOT 300 INLINE 6 CYL EFI
The TFI module is on the side of the distributor but I would recommend replacing the module and stator witch is inside the distributor..... Have you checked to see if you have voltage to the coil?
4helpful
2answers
Firing order for 1966 ford mustang 200 cubic inch
The engine is a 200 CID straight six, the firing order is 153624...
Just pop the distributor cap and have someone crank the engine while you watch the rotor.
How I can determine which hole in the distributor is assigned to the #1 plug wire.
Pull the number one plug. Turn the engine over slowly (with a wrench) while holding your finger over the plug hole. When the air builds (a lot of) pressure you are coming up to the number one spot on the distributor. (the rotor will point to the location of the #1 hole in the distributor.)
Quick methods to disable the engine I have seen people do on the classics:
Close the points by loosening the set screw
Pull the rotor cap
Connect a wire from the coil to ground. (effectively closes the points. Can damage the coil if key is left on.)
Pull the main ignition wire
And there are some tricks at the starter solonoid involving the ballast resistor bypass that is used to provide a hotter spark while cranking. (Two little wires at the starter solonoid - one is crank the other is the ballast bypass.)
Might give those a look-see. Best of luck (rememeber rated this help).
1helpful
Ned to now wat the firing order for dist cop shood be for a 1987 ford f100 pick-up truck 300sixcylender stick shift model#333
The F100 ended in 1983, so there is some confusion on your 1987 Ford F100. The F150 started in 1983 and was available in 1987, but not the F100. You have this listed under the 1981 Ford F100 category.
The 300 CID = 4.9L In-Line (Straight) 6-Cylinder.
In order to best answer your question I have included both the 1981 F100 4.9L and 1987 F150 4.9L below. The only difference is with the Distributor Cap Configuration and Connections.
For the 1981 F100 300cid=4.9L:
Firing order:
1-5-3-6-2-4
Cylinders:
(back)
...6
...5
...4
...3
...2
...1
(front)
Distributor:
...(back)
.........4..[.]-clip
...................1
6
................5
[.]....3
For the 1987 F150 300cid=4.9L:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
..6
..5
..4
..3
..2
..1
(front)
Distributor:
.......(back)
.................4
.....2
.......................1
..6
.........................[.]-clip
....................5
.......3
.........(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
1966 ford f100 will not start repalced points plugs wires coil voltage regulatornot getting any fire
Have you checked the starter solenoid? Replace this and see if you're getting fire then. They are usually suspect and the first link in the chain between your battery and the distributor.
5answers
Ford 351W
I agree, jumped timing. Check to make sure the dist is tight. Than check for tdc on the #1 cylinder. When the #1 cyl is TDC the rotor should be pointing to that wire on the cap. Take the cap off while checking. Also is easier to turn motor by hand without plugs in motor.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
