Question about Kenmore 24 in. 17602 / 17604 / 17609 Built-in Dishwasher
Need instruction manual
Need instructions for the soap dispenser. do you fill the dispenser to the top and close the hinged door then start the dish washing cycle?
  • 8,197 Answers
Yes you put the dishwasher soap in the soap dispenser. Then you close the lid to it. then shut the door and start the dishwasher.
Posted on Apr 19, 2010
6ya staff
SOURCE:
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
Soap tablet not being used,not washing dishes
I will assume a few things as you do not indicate which unit you have.
You have a soap dish with a door that should open at the correct point in the cycle. That is probably not happening. You can tell for sure if the soap dish door is still closed at the end of the cycle.
If the door is still shut then something could be jamming it or it is faulty.
Take a look at the dish door and look for soap residue and dirt etc collected around the hinges and the clip holding the door shut. Clean it out.
Open and close the door by hand a few times to ensure it operates freely.
No Go ?
The timer tells the door when to open and close. If the door is faulty or the timer is not sending the signal then the soap will not dispense.
To test the soap disperser you would open the door and move the timer to the position where the soap should be dispensed. Then put a test light across the terminals on the dispenser to see if it is getting a signal. If there is power then the disperser is faulty. It now power the timer is faulty. You would replace the part accordingly.
It is hard to explain in detail how to do the test as I don't know the exact unit.
Short term solution until you get it properly fixed is to use the puck or dissolving package type cleaner. Just put it in the bottom of the machine at the start or open the door mid cycle (unit stops when you open the door) and toss it in. It will work for now.
Hope this helps you with some direction. Please rate this answer if it helps you get started.
Mar 19, 2010 | Whirlpool 24 in. ADG7540 Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap dispenser
It sounds like the soap dispenser flap is stuck or the latch is broken. Try to see if it can be manually opened to loosen it. How long do you wait before starting the dishwasher after the soap is placed in the dispenser? Check and see if the cover opens even a little during the wash cycle?
There could be a problem with the solenoid that opens the soap dispenser. I don't know of the part number for this. You'd have to call Bosch or check their website.
Mike
Jan 25, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 24 in. 17602 / 17604 / 17609 Built-in Dishwasher Logo
168 people viewed this question
Top Kenmore Dishwashers Experts
Ron Rak
Ron Rak
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
