Paper Jam
hi...
1)After years of heavy use the rubber rollers which transport the paper
through the printer can get a shine to them and tend to loose their
grip. This causes misfeeds and blockages.
Using a damp cloth
and something like Jif (slightly abrasive kitchen/bathroom cleaner) rub
the rollers whilst rotating them by hand. With a clean damp cloth
remove any cleaner and you should see the rubber has lost it's sheen.
Some
rollers can be hard to get at but a little patience pays off. I've
reclaimed dozens of printers due to be scrapped in this way.
You
can also try turning the printer upside down and softly tapping it. You
could be surprised at what drops out. My best to date was pieces of an
illegal plant substance and a rare Chinese coin. (Yes it was returned
to the owner :-)
or
2)The flashing error code that indicates a jammed printer is the
digital-age equivalent of a flat tire. Sooner or later it happens to
everyone, so you'd better know how to get things moving again if you
want to finish your print job.
1. Turn the printer off and on to
see if it can automatically clear some or all of the jam. Many printers
provide an error-code listing on the front panel display for the area
where the jam occurred. If your printer shows an error code, be sure
and check the printer manual to see if that identifies the area of the
printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.
If you find a piece of jammed paper, remove it by holding it with both
hands and pulling firmly (see A). The goal is to keep the paper from
tearing. If several pieces are jammed together, try pulling out the
middle piece first to loosen the jam. (images 1 to 2)
7. If the
paper does tear, try rotating the roller gears manually to free the
paper (see B). Don't force anything, though. (Image 3)
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
thank you
