KitchenAid 24 in. KUDM25SH Built-in Dishwasher Logo
Question about KitchenAid 24 in. KUDM25SH Built-in Dishwasher
I do not know how to turn off child lock safety feature. How do I do this?
Posted by shellyk82 on
Anonymous
  • 949 Answers
To turn on or off the child lock
Press and hold the ENERGY SAVER DRY button for 4 seconds.
Here is a copy of the owners manual if you have any other questions.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209744037.pdf
Posted on Apr 19, 2010
LG Microwave MC8289UR/00 want to know if has child lock and how to turn on and off
Here is a section of the manual for your microwave on child lock, hope this helps.
"L" - Page 7 Press and hold STOP/CLEAR until " L " appears on the display and a BEEP sound is heard. The CHILD LOCK is now set. The time will disappear on the display . To cancel CHILD LOCK press and hold STOP/CLEAR until " L " disappears. You will hear a BEEP when it's released. If any button is pressed, "L" will appear on the display Your oven has a safety feature that prevents accidental running of the oven. Once the child lock is set, you will be unable to use any functions and no cooking can take place. However your child can still open the oven door. Press STOP/CLEAR. Child Lock 7
1helpful
I have a whirlpool microwave WM1107ADWC and I want to turn off the Child lock. How can I do it? I don't have kids and i want to save time when I use my microwave. Thanks
Child locks on microwaves act as a safety feature to prevent children from getting harmed or from causing other possible damage. The child safety lock does not lock access to the microwave; it simply prevents the microwave from being operated. To remove the child lock press the Stop button three times.
Lock the microwaveIf you wish to re-lock the microwave, perform a similar procedure. Instead of pressing the Stop button you need to press the Start button. Press the Start button three consecutive times to lock the microwave. This enables the child lock once again and prevents the microwave from being operated.
check this video also. Many Whirlpool microwaves are made by LG. between these two you should get it.
How do you remove the child lock on microwave
2answers
How do I turn of the child lock?
ON THE REAR PASSANGER DOOR INSIDE THE DOOR FRAM ON METAL PART SHOULD BE A SWITCH TO DISENGAGE CHILD SAFETY
LOCK
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
1helpful
Child safety lock on 2003 pontiac grand prix
should be a switch on the back doors to turn on and off the child safety locks it requires your key or a flat blade screw driver.. let me know if this works for you
CHILD SAFETY LOCK
If the model number you have this question posted under is correct, to cancel the child lock safety feature all you need to do is press and hold the zero "0" button for at least 4 seconds. The "LOCKED" indication will go away and you should hear two beeps. The instructions are listed on page 11 of the owner's manual. If you no longer have a manual, you can download or print a copy for FREE at managemyhome.com. Just type in your model number under the "Manuals" link.
If you have questions, or if your model number is different, please let me know. I hope this helps you.
1helpful
Is there a child proof lock on whirlpool duet gew9250pw and if so how do you unlock it for the dryer ??
Yes, there is a child safety control on the Whirlpool Duet. The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
1helpful
Control lock is on and don't know how to turn it off
Without knowing the manufacturer and model number, it is impossible to be specific. But most dishwashers that have a control lock light means that you have a child safety feature on the dishwasher. If you look closely, you may see some symbol that ties two buttons together and maybe if you press both at the same time, the child lock out may turn off.
Post info about the make and model here to get more specific.
May 06, 2009 • Dishwashers
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Interior locks
to set the child locks,on the back doors there should be a peice that you click down,its right on the latch assembly,if you set that to child locks on the only way to open is from the outside,doesnt matter if the vehicle is moving or not
Open Questions:
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
