Question about Whirlpool Washing Machines
Whirlpool washer stopped spinning...then started back, but it smells bad like burning rubber?
  • 343 Answers
An overheating motor can switch itself off. When it cools it will restart. And overheat again.....If the motor is hot to touch (unplugged, of course) That would verify the problem. Good luck......Nomess
Posted on Apr 21, 2010
6ya staff
SOURCE:
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Washer seems to be stuck on spin. Has slight oil/rubber burning smell. Will only advance out of spin if you manually turn the knob to the next step.
The timer is bad and needs to be replaced. if you continue to run it this way you will need to replace the motor coupling real soon. That is where the burning rubber smell coming from.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jan 20, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
I was washing wool that has a lot of lint and the washing machine stopped spinning and smelled like hot rubber. Is there a filter to clean in the washer?
The burning rubber smell is probably the belt. It is probably broken into. Remove the front of the washer on a top loader to access the belt at the bottom where the motor is.
Dec 29, 2010 | Whirlpool Washing Machines
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Whirlpool wash machine stopped spinning , motor stopped water did not leave- smelled of rubber
pump/or basket not spinning causing the belt not to turn thats the reason why is smells like rubber check pump and basket for free turning
Dec 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not spin and has a burning rubber smell
sounds like a loose belt, or worse, a stuck pulley..
tip the unit back about 30 degrees, with power off, and unplugged, and inspect the belt..I suggest something solid to hold it up(not your hand or someone elses)...and see if you have free play there, or it's frozen
Mar 24, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
83 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
