Likely the drain hose is kinked or blocked...Or the pump filter blocked or pump is faulty. Most likely the filter needs to be cleared. This should be accessed via a small hatch at floor level. Or behind the kickplate. unscrew filter and clean. Make sure the machine has no water in it. Leaning it back against the wall will help with visual inspection as well. Make sure coins haven't jammed in impeller. Good luck.....Nomess
