Question about HP Compaq Presario CQ50-110US Laptop
How to replace a cooling fan for Compaq Presario
Hi
Could you tell me how to replace a cooling fan for Compaq Presario CQ 50?
Posted by arthur031021 on
Anonymous
    New Friend:
  • 52 Answers
I would definitely consider taking it to a certified repair shop first.
If you must do it yourself, get the proper fan, (Which you can find on ebay for around $22 new), a set of small screwdrivers, and preferably an anti-static wrist band. You will likely need to take out every single screw in the thing to get to the fan. It will be fairly straight forward to replace unless you need to take off the heatsink, in which case the following information may be useful. If you can avoid taking off the heatsink do by all means.
As with all electronics wash your hands first, touch a ground (Typically your sink facet is grounded), and stay grounded if possible (With the wrist pad), and avoid touching any chips as the oils from your fingers can cause problems.
And always take the battery out and make sure it's not plugged in before starting anything!
The fan itself has a 3 wire connector, and will simply screw into place on the heatsink.
If you do remove the heatsink from the cpu you may want some heat transfer goo .
Some heatsinks now don't use heat transfer goo any more and have a pink pad that melts at high temps which helps transfer the heat.
I prefer arctic silver for the heat transfer goo, and to remove the old heat transfer goo before adding the new. Place a very small amount on the heatsink, enough to cover the part it makes contact with and no more, being very careful to not allow any air bubbles, and making sure it's spread evenly across the surface. Don't use your finger, use a flat edge to spread it, Maybe a box razor blade or something similar.
If it uses the pink pad, do not put heat transfer goo on as when the pad melts the transfer goo will mix with the pad and degrade the performance of heat transfer. Ensure the pink pad is in the same place it was when you removed it.
Put back together, ensuring every screw is back in, then cross your fingers and toes.
Posted on Apr 18, 2010
Compaq cq-45 laptop light near to caps and scroll blinks , No display
In Most cases this happens when using Nvidia graphics.
You need to open your laptop - call a technician for professional Job is you are not able to do so.
After removing the cooler which usually comes with a small fan (covers the main processor), remove the processor and you will see a chip that need a "HOT AIR STATION" this tool blows very high temperature of air on the surface.
well I used my wifes Hand Hair Dryer - also does the magic.
see image on where to blow the hot air.
now after blowing the hot air, mount your laptop again.
but first, let it cool down.
Sep 04, 2013 | Compaq Presario CQ-45 Laptop Universal AC...
Laptop heats up a lot
Please check your laptop internal fan. If it is working then try to place your laptop on flat surface and check the problem.Please don't place on bed or irregular surface. Laptop need air to cool.
Thank you for asking on fixya
Sep 30, 2012 | Compaq Presario Cq-62 15.6 Laptop Lcd Led...
Hi, My notebook is Hp presario cq series While i start the machine the cooling fan is not revolving and i hear some error message regarding the seriousness of the fan problem, A couple of days back...
Compaq notbook Presario 1626 is now officially retired at HP
https://support.hp.com/us-en/retired-products
beep codes, count them report them>>?
how to fix something but but dont touch it>? the is impossible
think that trough?>
most pcs pack in lent every year, its needs service
if not up do doing that your self, try a shop?
the fan must blow and keep the CPU cool or it overheats and fails
the CPU will shut its self down, if it overheats. ending all things..
until its cleaned fully.
google or you tube this. act.
hp forum is here.,
https://h30434.www3.hp.com/
Jul 17, 2017 | Compaq Presario 1626 Cooling Fan Case...
Laptop overheating and shutting down prematurely
Laptop heatup is mainly due the clogged heat sink and fan etc, which requires to be cleaned. Laptop shuts dwon automatically when reaches the temperature limit to prevent damage. It is strongly recommended that you clean the heat sink etc yourself or seek help from authorized professional at the earliest to avoid any damages to the PC.
If you are familiar with working inside such electronics, then you can do it yourself after studying the following useful links about CQ-50 Disassembly. On the contrary, if you dont have sufficient experience/ idea about opening/ repairing laptops, DONT try it and get assistance from a professional,
Dissassembly CQ-50
Maintenance & Service Guide CQ-50
Hope it helps! Do convey your feedback
CreativeTECH
Jan 27, 2011 | HP Compaq Presario CQ50-210US Notebook
Network adapter problems
hi yumaada;ew
dont worry about that problem...very simple..
1)first install ur operationg system (refresh) 2)install support drivers including bluetooth and lan
May 22, 2010 | Compaq Computers & Internet
Hi I am not able to connect internet .I dont have ethernet driver for my laptop. I am using windwos XP .I have compaq cq 50 106au laptop. Please help me to get ethernet driver for XP.
You can download it from here...
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3740387
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 14, 2010 | Compaq Presario Notebook
I have a HP Compaq Presario CQ-50. How can I
Delete any/all antivirus softwares on the computer. Restart computer and go here to download Panda free trial. Works great and after the trial I would suggest buying this software because it will save you from tech fees.
http://www.pandasecurity.com
Oct 03, 2009 | HP Compaq Presario CQ50-130US Notebook
Cooling Fan problems
clean/replace the fan or get a cooling pad usb
Aug 22, 2009 | Compaq Presario 1626 Cooling Fan Case...
HP Compaq Presario CQ50-110US Laptop Logo
2,604 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
