SOURCE: flm-3201
I would replace the control box assembly that is the most common issue with those TVs
SOURCE: When I plug it in the red remote stand-by light
flashing power light:
projection TV`s have many protective circuits in them, they protect
your CRT`s from damage, over voltage called x-ray, and many others, you
need to have it checked before the damage is more costly, your TV is
not happy and needs to be checked
This happens because the power source has failed. What has caused the failure can be found only by testing it - but my guess, based on how it behaves, is that the high tension for the panel is faulty: the filtering capacitors have failed and fried the rectifier.
