Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer will not drain
Whirlpool Ultimate Care II model LSQ8543JQ1 Washer fills and washes (although barely turns) but now it will not drain.
Can you tell me the problem?
Posted by dkclashley on
Jason Johnson
    President:
  • 1,619 Answers
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Posted on Apr 18, 2010
Gerry Harvey
    Genius:
  • Whirlpool Master
  • 1,482 Answers
You need to check pump/ filter not blocked ...
My whirlpool ultimate care ii is draining the moment I start the load... Is this normal?
No, the unit should not drain as it fills. Be sure that the drain hose is above the tub level.
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Washer will not fill up
IS YOUR DRAIN HOSE AT LEAST TO THE TOP OF THE MACHINE - OTHERWISE IT MAY RUN OUT OR SYPHON OUT/
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Marvin
Marvin
Mike
