Question about Sony Cyber-shot DSC-N2 Digital Camera
The screen on my sony dscn-n2 is broken where can i buy new screen?
Posted by artistadepec on
Shahid Electronics
  • 10,594 Answers
Part number of lcd for Sony DSC-N2 is as follows:
A1151474A... TP BLOCK ASSY (30STGU05) (including LCD)
Available in Sony Part Store for $192
Thanks.
Posted on Apr 18, 2010
Having problems with my DSC-N2. Screen is starting to take only dark pics even with the flash and sometimes there redish lines across the screen and also comes out in the pics
It sounds like a problem with the CCD imaging sensor itself. Most likely you will want to consider replacing the camera. You do have the option to contact sony and get an estimate. You can also contact/send it to a independent camera repair company and they commonly offer free estimates.
Here is sony's contact info:
https://eservice.sony.com/webrma/web/index.do
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=CONTACT
Thank you,
lee
Jan 26, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
I replaced LCD in my Sony DSC-T70 and i still have a white screen
HI samminowak Where did you buy the LCD for DSC-T70, can you provide me a link? I decided to put to the support store recommended by Sony Tech Support authorized dealers. Did u try to contact them?
Dec 10, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Zoom lense 'Slanted'
The parts (gears) are manufactured in plastics so once damaged it is very difficult to rebuild. Sony does not sell gears but complete lens assy. so best way is to find out what Sony charges for the repair. At www.camerarepairjapan.com the rebuilt of zoom repair was around $120 with 3 months warranty. Good luck. James
Mar 26, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Lcd screen
Below exploded view might help you to replace lcd screen of DSC-N2
Need further help, let me know...
Sep 14, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony n2 camara problem
ok guys, I was getting the same "Access" black screen on my dcsn2. I would turn it on and the lens would pop in and out I would get the black screen with the "Access" on it. What worked for me was the following:
As the lens came out i grabbed and pulled while it was fully extended
The "Access" screen disappeared and my camera was back to normal.
hope this works for u guys! :-)
Sep 09, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
195 people viewed this question
Top Sony Cameras Experts
 Larry
Larry
 MikeWang
MikeWang
Paul Green
Are you a Sony Camera Expert? Answer questions, earn points and help others
