Samsung HL-S5087W DLP TV Logo
Posted on Apr 18, 2010
I have a samsung HL-S5087W it will turn off by itself I have replaced the lamp and it continues to do this I have tryed to go to the service menue mute 182 power, I see a menue but go on options but cant see a lamp reset in option, maybe theres somthing I'm missing???
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
471
Points
Your problem is your No 2 Fan needs to be replace I have had the same thing happen to me.
HL-S5087W IS WORKING RIGHT NOW, BEAUTIFUL PICTURE BUT AFTER 20 MINUTES THE PICTURE GET OUT. THE LAMP IS NEW.
I went through the same exact thing. I had to replace the DMD board. No problem after that.
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
6helpful
2answers
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
My Samsung HLS5087W keeps turning off by itself.
need to replace the lamp to correct this issue
1helpful
Samsung HL-S5087W DLP rear projection TV keeps shut off and won't stay on longer than 30 seconds.
your bulb has reached the end of its life (at least this is what your tv thinks) you need to replace the bulb and or make the think you did. (there is a reset in the service menu for the bulb)
5helpful
HL-S5087W has become dim in picture
if the colors look good and its just dim its the lamp. usually the lamp will show signs of being bad by looking at the base of the shaft in the middle if its discolored or warped the lamp is bad
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
2answers
Samsung hl-r6178w 3 blinking lights
The power board ic converter is dead.
U can tries to go to the web buy the part and replace it yourself.Or hire the repair man part and labor $575
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
