If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
I've finally found how to turn off the annoying alarms in gshock by solution given in below blog.
http://allinfoatoneplace.blogspot.in/2012/10/how-to-turn-off-alarm-and-hourly-time.html
SOURCE: Do not know how to
I had the same nagging problem on my GSHOCK 2816. The Casio manual was no help at all. What I did to turn my alarm(s) (mine has 5 independant alarms) off is switch to alarm mode (as you are looking at the face of the watch, it's the bottom left button. I push it twice to get to alarm mode. My display shows the current alarm time, and then the number 1. If you hit the top right button on the watch, it turns this alarm off. If you hit the bottom right button, it cycles to the next alarm in the list. To set an alarm, just cycle to the one you want, and then hold the top-left button until you see it flashing, then use the right side buttons to adjust the time. Hope that helps. This was a big pain in the **** until I figured it out.
SOURCE: Turn off alarm
go to alarm mode and choose the alarm (1-5) using the "forward" and "reverse" buttons, then hold the bottom right button down to toggle it on or off
SOURCE: adjust the time in a casio g-shock shock resist watch
You can get instructions from the Casio web site.
Go to the
watches;
Accept terms
Read
Click
on "search" and the download your instructions.
SOURCE: watch alarm
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
