Whirlpool Home AppliancesWe have provided many important safety messages in this manual and on your appliance. Always ... Read all instructions before using the microwave oven.
PanasonicWe have provided important safety messages in this manual and on your appliance. ....Thank you for purchasing a Panasonic Microwave Oven. WARNING ...
exposure to microwave energy. 3. Warning: Only allow children to use the oven without supervision when adequate instructions have been given so that the.
used the info on the website to troubleshoot the issue. Determined it was the thermostat. Replaced it. Seems to work fine. Could not have done this without the illustrations showing where to find the thermostat and oven sensor. Great help.
F30 is a warning code indicating that the oven either has overheated or that the sensor may have activated the error code.
There is a sensor inside the oven that should have a resistance of about 1,100 Ohms at room temperature. If the resistance is out of range then you will need to replace the sensor.
If the resistance is within tolerances then the problem is the clock control board. Also check for any loose or bad connections.
Hi.
Although I am not familiar with this model, it sounds like an overheating problem to me, could be a faulty thermostat, and the error code could be a warning of this.
Sorry I can't help you further. Please leave feeedback
Consider having the Direct Ignition Module checked. These are notorious for shutting down due to an acknowledged poor design; interior unit overheating & oil leaking, that can result in the car shutting down without warning & in some cases, electrical fires. Saab issued a recall on this for model years 2000-02. Replacement is simple (4 bolts & electrical connector) but can cost $250-$500 if done by urself or close to $1000 at a dealer. - Spooky0508
