Apple iPhone 3G Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The volume on my iphone is at max but I cannot
The volume on my iphone is at max but is still so low that unless I am in an absolutely silent place I cannot hear the voices of callers. How can I fix this?
electronic & computer repair& servicre
Level 3:
  • Apple Master 12,061 Answers
  • Posted on Apr 18, 2010
Apple Master
Level 3:
Answers
12061
Questions
0
Helped
4006229
Points
36390
You most likely need to have your speaker replaced. Perhaps something, moisture, has gained egress into the ear-piece?
2answers
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
1helpful
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 • Cell Phones
2helpful
My receiver on my Iphone is low how can i increase the volume mind you the volume is at max
If the receiver is that low (and the volume level is at max) there may be a hardware issue related to the internal receiver. The piece is replaceable, but must be serviced by Apple or have your iPhone replaced by AT&T (if under warranty).
In some models of iPhones, this was a known issue that would occur through normal wear & tear. An easy way to tell if it is a hardware issue is to pair your iPhone with a bluetooth headset. While keeping the volume level at max, is it louder or the same as the iPhone's built-in receiver?
If it is louder, than chances are pretty good that the internet receiver needs replacing. If not, then you may have a software issue affecting the sound levels. Try rebooting your iPhone as this tends to "fix" a great many issues affecting iPhones. If that doesn't solve it, perform a sync to backup data, next update or restore your iPhone and then perform the test again.
2helpful
2answers
My i phone 3gs does not ring, the volume control is on max
On the left hand side of the Iphone you will be having a slider kind of a thing which can be used to toggle from silent to ringing mode. Check if that set to silent mode.
1helpful
Low volume on calls. cannot hear caller unless i'm in an absolutely quiet room. I have the master volume at max. also, the flash is so bright that the pics i take are overexposed. Can i shut the flash off...
for the low volume, the fault is from the earpiece. Trust me, I faced this same problem and when I changed the ear piece, I began to hear calls clearly.
You could also get a earphone and use it to receive and make call pending the time you get the earpiece fixed. Earphone will even be much louder.
Concerning the flash, do some adjustment settings as you rightly suggested.
I wish you the best.
Dec 31, 2009 • Cell Phones
No ringtone when receiving a call
Check if your iPhone is not in silent mode. Push the Ring/Silent switch upwards to turn off silent mode. You'll know that the silent mode is not on when you don't see the small red dot at the Ring/Silent switch which is located just above the volume buttons.
Take a look at this:
for more iPhone / iPod touch tips, click here.
2helpful
3answers
IPhone 3G Bluetooth microphone volume to low
This is a Normal problem, remeber the echo is for the mircrophone is in the same place like the speakers, & dont have a noice cancelation system, I recomended to use a bluetooth earphone
2answers
3g iphone low volume, dropped calls, low bars when you just turn your head ,standing in the same place?
Mine drope the calls and the Apple Bluetooth hands free does not work in my 3G, the volume is very low, and with my old Iphone was great.
26helpful
6answers
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Ringer
contact me on email id
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
