Question about Philips GOGEAR SA6045 MP3 Player
It will not let me add videos any more and my memory is not full i still have space
Posted by dextergirl96 on
Fathi Elmahdi
  • 1,871 Answers
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
I recommend you to reset your device If the solution above didn't solve the problem :.
Take a small object like a paper clip and use the edge to stick into the small reset button on the side next to the usb connection .
Or Try [ power + volume up button & hold for 3 seconds ]
Your mp3 player has two types of memory in it. The hard drive (where the music and photos are stored) and the Ram (where the firmware and active files are temporarily hosted).
When you soft reset your GoGear, it flushes the RAM, and restarts the operating system (which is why the contents of the hard drive does not get erased).
You can "hard reset" the device, by formatting the drive and resetting it to factory defaults in the Settings field. This is the closest thing to a "hard reset: that's available with an HD based MP3 player.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 18, 2010
Ram is almost full on my 530 need to know how to increase it or erase it?
RAM is random Access memory if it is too full then you need to shut off some programs and use them one at a time or find older copies of the programs your running which do not take so much space.
Oct 27, 2014 | Computers & Internet
What can i do when i receive internal storage space too full on android
Either delete some data! Music, videos or if available depending on make, model add a memory card!
Oct 25, 2014 | Cell Phones
What does internal memory full mean?
See my response to your other post. When the internal memory is full, it can hold no more pictures. You can free up space by deleting pictures. You can add space by inserting a compatible memory card.
Nov 23, 2012 | Kodak EasyShare M530 Digital Camera
Why doesn't it take picture's when you push the button , it say insert memory card , memory is full
Sounds like one needs to delete the pictures on the internal memory in order to free up space or add an empty memory card.
Aug 17, 2010 | Vivitar ViviCam 8025 Digital Camera
My dell dimension 3000 pc has run out of memory space on the C-drive. How do I add more memory?
You can't directly add additional memory space to the C drive, but you can add additional hard drive and move the files from C drive to the additional drive. If there's enough space on D or E drive, you can move from C drive to the other drive. Note that your C drive includes your Desktop, My Documents files, My videos, My pictures, My Music etc.. So make sure you haven't saved extra files on you Desktop or My Documents. To free up some space, you can run DiskCleanup utility which is built-in with the Operating System. To do this, Right click on the C drive, Properties - Disk Cleanup... and then provide positive input, eg. yes or ok. good luck..
May 14, 2010 | Dell Dimension 3000 PC Desktop
Cell Phone Calendar Out of Memory
Hi, the calender feature on your phone is stored on the phone memory, so adding a memory SD will not have any effect concerning the calender expect for features like musics, videos and pictures.
What you will have to do is to delete some unnecessary information you have on the phone memory to pave more space for the calender.
Take care
Mar 19, 2010 | Pantech Matrix Cell Phone
Memory stick duo reads full but it is not really that full
There is a reserved amount of unused space that is required for files used to run it.
Think of it this way,A blank disk will show nothing.Add a one word document and write protect the disk,It will show the disk is full,Even though you know it only has one word written to it.
Please rate this a fixya
Jan 30, 2009 | Koutech Systems Koutech KW-2103MS Memory...
My Sansadisk want let me add music to it.
You are attempting to add music to the disk function on your device make sure it is on the mtp function so that all of your memory is avalable. this is done when you dturn it on and then hook up to your computer. You'll figure it out I did the same thing a couple times - Good Luck
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
360 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
