I was just asking for the make and model # of the dishwasher. With out that we can not help you.I was just asking for the make and model # of the dishwasher. With out that we can not help you.
You can't post conmments that contain an email address.
There should not be a childproof lock on your microwave.
However, it is remotely possible that there is electrical failure preventing the door opening.
Most, not all, microwaves can be taken apart with screws with the door closed.
See if you can do yours.
You should find the latch holding the door is broken or stuck or whatever.
God bless your efforts.
Press and hold down gently the LOC button for 5 seconds or more, the light will go off - your machine is unlocked !! You do it again & the machine is locked. This is a tamper proof device against children. Gud luck. Comment?
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The drying process will stop. Open the door at Pause position and close it again after adding or removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in the machine to intermingle with wet clothes and the result will be wet laundry after the drying process is over. It is not recommended to add laundry after the programme is started as it will increase the programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys while the programme is on. The loading door and all keys except the ON/OFF key on the panel are deactivated when the childproof lock is active. In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel buttons simultaneously for 3 seconds.
Fig.6 Using the childproof lock
To start a new programme after the programme is over or to interrupt the programme, the childproof lock should be deactivated. To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
This depends on the exact model of the KitchenAid Superba dishwasher. There is a button on the control panel that will indicate the Control Panel Lock. Usually this is labeled Control Lock (Hold 3 sec) or 4 Hour Delay (Control Lck 3 Sec). The phrase in parentheses is below the key in a smaller font.
Press and hold the button to toggle the lock on and off. Sometimes you have to hold it for more than the listed 3 seconds.
I hope this helps.
Cindy Wells (my reference was the manual for the KitchenAid KUDE40FXSP . Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Just enter the model number and the type of person researching the documentation (consumer).)
