Question about Kenmore Kitchen Ranges
Got F40 error code self-cleaning my 790.9642 Kenmore range
Got an F40 error code at the end of self-cleaning my Kenmore range. Reset the alarm....a few minutes later it came up again and reset again. The cooktop/door eventually unlocked, but the error concerns me.The range appears to be working fine otherwise.
Posted by der1030 on
carl
  • 3,640 Answers
Try this, after several calls I finally found out what the code meant. code meant. Power supply issues, not necessarily with your power supply but with the applianceGot F40 error code self-cleaning my 790.9642 Kenmo - 2_bing.gif itself. Of course they want to send a technician for $65.00, which may be worth the headache. All someone told me was to turn off the power braker for 2 hours and try again. Yeah right, after 2 hours of heating your house and paying the electric bill, but when breaker is off there will not be any electric used. code f40,
Posted on Apr 19, 2010
Trying to find out what f40 error code for my kenmore electric range 790.96423408 during self cleaning mode is?
Looks like you will have to call a technician.
It's a 'cook top lock out error.'
Check out this site -
ShopYourWay
Jan 03, 2018 | Kenmore Kitchen Ranges
Kenmore fault codes
it is a cooktop lockout error and usually occurs after or during the oven self clean process. If this is the case then let the oven cool down after self clean and see if it goes away. Most likely the wiring harness containing the signals from sensor to the control module is damaged. If it persists you will need to get a technician in.
Aug 24, 2014 | Kitchen Ranges
How do I fix an F40 code on a kenmore elite rlectric range model #790.46709603
The "F40" fault code indicates a Cooktop Lockout error. There is a "Lockout" control board that locks out the cooktop from operating whenever the "Clean" cycle is used. It's not normal to display "F40" unless there is a "Lockout" or an "EOC" (electronic oven control) failure. It may need one or the other or both boards replaced. If the cooktop will operate after the range has cooled and unlocked then it may need the EOC and not the Lockout board. If you can ignore the beeping and the F40 and the range will heat up again in the clean cycle and complete the clean cycle then it could have a faulty Lockout board. Here a link to a YouTube video with the instructions on how to access and replace the EOC.
Here is the lockout board if you need to order it.
Here is the EOC board if you should need it also.
All parts come with a 365 day, any part, any reason return policy.
Apr 06, 2013 | Kitchen Ranges
Range beeps every few minutes
Typically this means the cycle is completed or there is an error detected. Reset the unit at the household circuit breaker fora bout 10 minutes, then retry the unit. Let me know if this happens again. Also let me know if you see any alpha-numeric error codes.
Aug 31, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning lock
first put it on cleaning mode again for few minuts and then press cancle .. that should reset the program if it is not working your control panel might be damage :(
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F40 code
It worked for me.  When the power is off, there is no electricity being used, thus no charge.
Nov 06, 2008 | Kenmore 92002 / 92004 Kitchen Range
Kenmore oven locked after celf cleaning
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Kitchen Ranges Logo
1,616 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
