Sylvania SRT2319 TV Logo
Posted on Apr 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
I CAN NOT FIGURE OUT HOW TO HOOKUP MY NEW MAGNAVOX DVD/VCR PLAYER TO MY TV. ON MY TV I DON'T HAVE ANYTHING BUT AN ANTENNA CONNECTION.
Anonymous
Level 3:
  • Master 666 Answers
  • Posted on Apr 18, 2010
Anonymous
Master
Level 3:
Answers
666
Questions
0
Helped
204839
Points
1944
May be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Hooking a magnavox vcr dvd player to a tv
You need what they call an "RF Modulator". They are about 25$. Here is a link to one...
http://www.radioshack.com/product/index.jsp?productId=2103095
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
2answers
Coaxial cord won't fit on VCR/DVD
Are you sure that the port that is unthreaded is actually coaxial. I've never seen an unthreaded coaxial port, just unthreaded push on connectors.
What color do you see on the center ring on the connection of the vcr?
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
5helpful
3answers
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
I am trying to set the dvd player up and can't figure where the red white and yellow plugs go. i have dishnet also is there a diagram somewhere that i could look at?
at the back of the dvd player u will find all three colours with the appropriate labeling (red for audio out right, white for audio out left and yellow for video out) the other ends of the cable plugs to the tv audio/video input match colours
2answers
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
2answers
Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
3answers
Can't setup Magnavox DVD VCR recorder
Put your TV onto chanel 3 to pick up your Magnvox signal
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
