Question about Toshiba 57H82 57" Rear Projection Television
My Toshiba cinema series HD separates the red & blue color.
My Toshiba cinema series HD separates the red and blue color. How can it be fixed?
  • Toshiba Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix hereMy Toshiba cinema series HD separates the red & - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
I have a 55 in Toshiba Cinema Series HD the colors are out of alignment so I have three pictures stacked behind each other. Is there an adjustment or repiar
I have a Cinama Series HD Toshiba and it has a Problem with the picture theres red letters behind the white , it like the colors are stretched, theres red eye above the real eyes and same with the teeth area, what could be the problem?
Nov 09, 2010 | Toshiba TN61X81 61" Rear Projection...
Color convergence issue.
Yes,U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairworld.com to buy a convergence to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 27, 2010 | Toshiba 55H70 55" Rear Projection...
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Toshiba Cimema Series 55''
most probably the convergence is going bad, enter the menu and realign the converg. match the red to green and the blue to green
Aug 17, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 50HX70 convergence problem
replace convergence ic,s part # stk392-110, you will need two of them.
May 12, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
1,394 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
