Question about Brother MFC-9840CDW Laser Printer
Connot connect printer to wireless router
I bought a bother mfc-9840 wireless printer. When I try to connect it to a wireless route,I got always connect NG message. I have tried 20 times, Even I reset many time printer, I got the same message.
I have a PC, It can connect to wireless router. So I think it is not router problem.
Posted by jmqin_1999 on
Manikandan Raj
    Guru:
  • 825 Answers
This may be due to the security password that is enabled in the router... its recommended to use WEP password in router to connect wireless devices...if you use any other encryption type like WPA/WPA2 then change it to WEP and connect it....if it is a belkin router then you need to disable the WiFi protected setup too.......
Posted on Apr 20, 2010
Mfc 7840w wireless printer through bell router
How do I connect a Brother MFC 7840W printer to a Bell Network. Every time I try to connect, I get a connection NG message on the printer. Any help would be greatly appreciated
Nov 14, 2012 | Brother MFC-8870dw Wireless Multifunction...
Need installation driver disc for a brother mfc 9840 cdw copier
You can download the Brother printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Aug 10, 2012 | Brother MFC-9840CDW Laser Printer
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
BROTHER MFC-6490CW won't connect to wireless router
Having the same issue with 6490CW and Uverse internet. It connected just fine to my wireless when I had AT&T DSL. Well, just fine is an overstatement, it would constantly go "offline" and need to be re-connected but at least it printed fine when it was. Now, I switched to Uverse and it WILL NOT connect wirelessly. I went the cabled ethernet route and it STILL has tons of issues recognizing the printer and printing, often stopping mid print and spitting out a half printed page or just not printing at all and telling me the printer is turned off. Next step is to try connecting with a straight up USB connection, bypassing the network completely. I feel like that's my only option short of getting a new printer. Brother's software simply does not work with some networks it seems. I guess it has issues with FIOS as well. This does not surprise me and it is also not surprising that Brother has not updated the drivers for my printer since 2009. Pretty ridiculous since things have changed a lot on the technology front in almost 4 years.
Jun 27, 2010 | Brother MFC 6490CW InkJet Printer
Brother MFC-9440CN Laser Printer how do i set
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Apr 03, 2010 | Brother MFC-9440CN Laser Printer
I have the MFC-490CW, I am trying to install it to be wireless. But I can't figure out some of the items. How do I find the WEP key?
My brother MFC490-CW is connected wirelessly to the router. It printed OK wirelessly yesterday when I set it up but today it will not print. The printer has a strong wireless connection to the router. My PC also has a strong connection to the router. But the printer seems to have lost the connection to my PC. How to I re-establish the wireless connection from the printer to my PC?
Nov 03, 2009 | Brother MFC 490cw Color Inkjet...
I have the same problem.
Try to ping the ip address of the printer. If its not responding then check the connectivity of the printer.
Aug 14, 2009 | Brother MFC 490cw Color Inkjet...
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MFC-9840CDW Laser Printer Logo
1,422 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
