Question about Sony CDX-M630 CD Player
Where is the auxiliary input on the sony cdxm360
Where is the auxiliary input on the sony cdx-m360
Posted by jklail5631 on
2 Related Answers
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: There is a auxiliary button on the sony cdx-m8800.
Well if it has a headphone jack on the faceplate then yes but this does not support the ipod directly if it does not have the mp3 jack kit you have to buy that from a place that sales sterio's Good luck i know it can be done but not directly. Please hit the ACCEPT button and give a good review thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 18, 2009
wyno62
wayne
  • 364 Answers
SOURCE: is sony cdx gt24 has an ability to connect
From memory I believe you can, it should have the 2 connecting jacks and speaker jacks in the back, let me know how you go. Good luck
Posted on Nov 20, 2009
Where is the aux input on the sony cdx-mp70?
check the front of the player. If you don't find any Aux input then it means your player does not have Aux input.
Take care.
Whats the aux 4?
AUX MEANS AUXILIARY INPUT, THAT WOULD BE LIKE AN IPOD OR OTHER DEVICE LIKE IT
Where is the aux input located?
aux, just means Auxiliary, or An Extra, it is any other input or output that the unit has in it, that can be used. There is a "Main" input, and any other ones are considered "AUX" or an extra one as well.
Is sony cdx gt24 has an ability to connect in an amplifier? its has an auxiliary in front and its mp3 player... Max. output 4 x 45W...
2helpful
IPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
1helpful
Aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Having problems hooking up an ipod.
The "bus audio input" works as an auxiliary input on some Sony decks, but not all. For the others, you need an auxiliary input adapter like this one: http://www.crutchfield.com/S-Yln489DwSWp/cgi-bin/prodview.asp?i=127AUXONS You can also use a Sony iPod adapter that will charge the iPod and let you control it through the head unit controls: http://www.crutchfield.com/S-Yln489DwSWp/cgi-bin/ProdView.asp?g=305250&I=158XA110IP&search=sony+iPod
Audio in
Unfortunately, the "Bus audio in" jacks are only for use with Sony add-on components, like Sony CD changers. Without a Sony component connected to the Bus control jack, the audio input can't be selected. To add an auxiliary input to this head unit, you need to purchase an adapter: http://www.crutchfield.com/S-EMPSKmYtPsH/cgi-bin/ProdView.asp?search=sony+aux&i=127AUXONS
4helpful
2answers
Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
Sony CDX-M630 CD Player Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
