I got my new LG French door 7 months ago--one month ago we changed the filter. It seems like water in dripping from the filter and collecting a massive amount of frost and ice in the freeze. I did take the filter out and put in back in but no luck--help...
The o rings are not cracked but the container the filter goes into has some water drops on the outside of it.The o rings are not cracked but the container the filter goes into has some water drops on the outside of it.
You can't post conmments that contain an email address.
If the filter is okay it must be a problem with the fridge, as it 7 months old it will still be under warranty.If the filter is okay it must be a problem with the fridge, as it 7 months old it will still be under warranty.
Please check there https://manualsbrain.com/en/brands/samsung/fridge-freezers/ for a manual to your fridge (or a fridge-freezer, as Samsung produces both). Hope it's helpful :)
It sounds like the water filter needs changed. Yes I see It's only been one month. Also make sure you have good water pressure to the frig. I hope this helps.
1st make sure you got water to the frig.
defrost the frig by turning it off for 2 days with the doors open. Sometime the water freezes inside the door and the water dispenser doesnt work. the turn back on and see if you have water. every 6 months you should change the filter (it could be the problem too)
Have you changed your filter? Make sure to change these every 6 months, I believe. Also, if your filter is new/ or within the 6 months, you may have a water valve issue. You'll need to replace the water valve, which is on the back of the unit, towards the bottom, behind the panel. You can remove the panel, its all Phillip screws.
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
