I have a liebherr freezer with ice maker. ice maker broken
I have a liebherr freezer with ice maker. The ice maker is not making ice properly and thr box fills with water and freezes also water collects at the bottom of the freezer and freezes. Any ideas?
Re: I have a liebherr freezer with ice maker. ice maker...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
It is telling you something is wrong! Check your manual for what the warning light signifies and take appropriate action. Look under troubleshooting. Also check out support at web site for manufacturer.
dear sir/madam
please make sure first your freezer,s defrost mode selecter set on auto mode or it,s set on auto defrosting mode. if it.s or freezer making continuously ice in ice bin then defrosting control device or temperaturecontroller is not working for repair it please contact to your maintenance personnel for replace it .i hope after that it will work properly.
Hello there: There's no iceIf your ice maker has stopped producing ice completely, check these, in this order:It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Ice not being manufactured instead water filling bin & freezing
