Question about Maytag MAH8700A Front Load Washer
We own a maytag neptune washer and it keeps saying Sr what does that mean?
Posted by kyiaraclark4 on
Larry Tee
    New Friend:
    Problem Solver:
  • 5 Answers
This happens to my Neptune washer a few times a year. See this page for a simple "no tools" procedure that has worked every time to stop Sr and the associated beeps. If this procedure ever stops working then I'll believe that the board has a real problem and I'll replace it or replace the whole machine.
Posted on Aug 12, 2014
dweatherby
    Sergeant:
  • 239 Answers
Need to replace mainboard
Posted on Apr 18, 2010
  • Larry Tee Aug 12, 2014
    I apologize for the accidental double-post. The missing "this page" link is in my above "answer".
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah5500b sr code
Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Evaluate wire harness for loose or unhooked connections.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
There is an intermittent chime going off and it is say SR-5 on the screen
Found the manual which says it is a control problem and machine needs to be serviced.
Feb 08, 2010 | Maytag Neptune MAH6700A Front Load Washer
What does the code Sr mean on a maytag neptune front load washer
Technical Manual say "System Relay Failure"
Diagnostic Code 34
Jul 16, 2009 | Maytag MAH8700A Front Load Washer
Maytag Neptune Washer Problem
replace the door latch wax motor and check the drain pump for obstructions.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag MAH8700A Front Load Washer Logo
390 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
