There are no Windows 7 drivers for this motherboard. Normally you'd have to buy a graphics card, but you might try this:
"Use the latest XP driver. (link below) save it to your desktop and right click it and run it in compatibility mode for XP service pack 3 and then run as Administrator, it will then install as if it were running on xp and then you will be able to have normal graphics."
please visit the website below and search for your board 845 then select your operating system in the right hand box and the drivers that are available will be show below hope this has helped http://downloadcenter.intel.com/Default.aspx
Download IDE application accelerator IATA_ENU.EXE, LAN driver 82562ET,graphics driver 845G chipset,audio driver Realtek AC97,USB 2.0.EXE,USB QFE for USB support.
hello
if drivers are not installed then try it using another way that is go to my computer icon on desktop right click on it go to properties,new tab is opened,go to hardware,device manager,new tab opened,click on display adapter,right click on your moteher board model,then update your driver from cd
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS.... (This solution works for any Intel Motherboard)
No need to donwload or install any drivers. Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key and Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher" 2. Leave "Primary Video Adapter" as "Integrated" 3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button" 2. Right click on "Computer" 3. Select "Properties" option from the context menu. 4. Scroll down and find "Disply Settings" option and click it. 5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
