Question about Peg Perego Vespa Scooter
My Vespa PX125 Disc loses power on the journey.
My Vespa PX125 Disc starts OK, fuel on, choke closed. After a short distance I loose power, and I have to restart with choke open
to get is going again , I return choke to close ,It travals a few metres then loses power again.
Posted by ron_harding on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Adjust air mixture screw at rear of carb tighten it first then loosen it 1& half turns give it a go
Posted on Apr 23, 2010
How to decrease the exhaust sound of Vespa PX150
there must be holes in the muffler caused by rust - replace it with a new original one...
Vespa PX 125 Stock exhaust vs Sip Road Sport 2 0
Apr 04, 2017 | 2005 Vespa PX 150
Engine stops when choke set to center
is there a way to increase the tick over speed if you can increase this it will be ok some times the metal bar that the throttle wire is atatched to bends slightley or the screw comes lose and it moves causing it to tick over more slowley
Aug 25, 2012 | Cars & Trucks
Seat is jammed on my px125
if the lock is surely open then you could use a strong flashlight and lift the seat a little with a big screwdriver (or crowbar) in the small gap between fuel tank and seat.
- then you can see the lock and try to move/turn it somehow until it pops open.
Aug 18, 2012 | 2007 Vespa PX 125
Vespa px side panels
the newer PX have the side cover latch under the seat
- see picture
the older ones have them at the lower front of the side covers
- see picture
Jun 03, 2012 | 2008 Vespa PX125
Gears clunk when change on vespa px 125
don't worry -the clunk noise is typical when changing gears on a Vespa 125 PX
- it is due to a very old fashioned construction in the gearbox (1940ies) see pictures:
you have to get used to that or change to a newer automatic type Vespa....
May 22, 2012 | 2005 Vespa PX 125
T5 starts but no lights horn indicators fuel gauge any ideas
Check the main fuse near the battery, it have been poped up and needs to be replace wit the same amperage. If the fuse blow up again, check your wiring there might be a cut or expose wire that maybe grounding the body.
Try also to check the electrical connectors, it might only been disconnected or needs some cleaning up on the contact pins.
Hope that helps you out.
Thanks for using FixYa!
Jul 03, 2011 | 2008 Vespa PX125
Hello, What type/grade oil do i use in my: .03 Vespa PX125 Gearbox?
Hi! You model of vespa uses about 1 1/4 pints of either 90 gear oil or SAE 30 motor oil. Please make sure you choose specific oil for motorcycles, because car motor oil will ruin your clutch discs (it has anti-friction properties that don't work well on wet clutch systems. Hope this helps! Regards.
Feb 22, 2011 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
490 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
