Question about Nokia 3230
My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can you offer me solutions for this?
Posted by safras1982 on
Anonymous
    New Friend:
My nokia 3230 failed to start up.... Answer Failed: retry My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which... (More) (More) My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can you offer me solutions for this?
Posted on May 04, 2010
My nokia 3230 is not starting up. just NOKIA brand name blinks on the screen. I have used soft as well as hard format the phone
Dear Sir,
I used opera mini 4.2 web browser in nokia 3230. When I download the song, not show the save option in mobile. Please suggest me how to download the song file in nokia 3230. I hope, you will accede my request.
Sep 06, 2010 | Nokia 3230
Help please! My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the...
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Mar 29, 2010 | Nokia 3230 Cellular Phone
My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a white screen appears but the phone does not start. Can you pls offer me a solution for...
well your phone will need full format try this way
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 04, 2010 | Nokia 3230 Cellular Phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 2630111022 (Unlock code)
Follow this instruction carefully
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1 - Switch on your Nokia 3230 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3230.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3230 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE (2630111022) you need to enter is the unique unlock code for your Nokia 3230
Nov 08, 2009 | Nokia 3230 Cellular Phone
See White Screen + Nokia Logo + Failed to Start contact Retailer
Try formatting your phone and see if it works.
First make sure your phone is turned off.Then press the following buttons simultaneously (at the same time:
Power button + * + 3
This will restore and reformat your phone into factory settings. Hopefully your phone will be able to start again as if it were being used the first time from the box.
Let me know if it works,
Hope I have been of assistance to you,
Cheers :)
Sep 03, 2009 | Nokia 3230
Start up problem
Hi Friend,
As you have mentioned that you have problem in the switch ON and OFF status,so kindly follows the below mentioned steps,which is known as hard reset as follows,
1.Switch OFF the mobile
2.Remove the sim card,battery and the memory card.
3.Hold the Switch ON/OFF button for 20 to 30 secs.
4.Replace the battery and the sim card alone.
5.Switch ON the mobile
6.After it has been switched ON about 1 to 2 minutes after replace the memory card
Check it and revert back
Thanks for using Fixya
Regards,
Ayyasam
Jul 17, 2009 | Nokia 7610
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
Nokia 3230
how to flash up the phone
Apr 14, 2008 | Nokia 3230 Cellular Phone
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye [email protected]
Sep 11, 2007 | Nokia 3230 Cellular Phone
Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
Sep 09, 2007 | Nokia 3230
Nokia 3230 Logo
420 people viewed this question
Top Nokia Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
sandyp4ever
sandyp4ever
Level 1 Expert
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
