Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
I have on Sony KDF55E2000. 55 inch projection TV. Everything was fine until coming home one night and turning on TV. The power wont stay on anymore. It comes on after warming up and then shuts down after about 10 seconds of being on. The green power light will blink around 40 times before coming back on for another 5 to 10 seconds and repeating cycle again. It will do this for as long as the TV is plugged in and turned on. Also, you can hear the fan running somewhat loud when it is in the off cycle and the power light is flashing. It stops running when it comes back on. Ive done alot of research and have no definitive answer yet. Any help would be appreciated. Thanks.
Posted by whitesox_74 on
Shahid Electronics
  • 10,594 Answers
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Posted on Apr 17, 2010
"My sony bravia kdf46e3000 wont always light the lamp when first turning tv on. I can see it sparks the lamp but the lamp only stays lit for about 3 seconds. The power light on the front stays green a
does the lamp fan stay on? you can see thru the back if the fan is running. If it is not running you need to replace it.
If it running you may need a new lamp driver/ballast part# 1-480-180-21 https://www.encompassparts.com/model/SONKDF46E3000/_/_/Sony/KDF46E3000/
then there is the possibility the new lamp is bad,, Sony's like Sony OEM lamps
Dec 20, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
Apr 01, 2009 | Sony Televison & Video
SONY KP 51WS500 - Volume & Menu won't stay on
This would be weird for a sony but it sounds like the volume down button on the front of the set is stuck...very very uncommon for a sony. Try taking the bottom front cover off the set and unpluging the button assyembly then see if the remote works the set with it unpluged.
Tim nolan
Sep 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi projection tv
power supply and it will cost 3 to 400 to repair
Aug 04, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sony wega 61 inch (odessa, tx)
TV is a Sony WEGA 61" model # KDF-E60A20
May 28, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
