I have a babylo stroller, and i have lost the plastic clip that keeps it shut when folded up can i get a replacement one? it just clips onto the two upright bars to fix it in place
SOURCE: broken clip to keep techno xt folded up
I had the same problem, but mine did not happened at an airplane. I went back to the store I purchased it here in Miami and they sent me to a authorized repair shop for Maclaren strollers., it was not covered on the warranty. But in 15 minutes and $20 I had it repaired with a new clip. Check for dealers in your neighborhood.
SOURCE: Laying Down and Folding Maclaren Triumph Stroller
Folding takes some getting used to, broke the first one I had because I used force. Here are some step by step instructions...http://www.strollerreviewguide.com/how_to_unfold_and_fold_maclaren_stroller_step_by_step
-Good Luck!
SOURCE: how do i fold up
If it's stopped folding something has jammed the mechanism best to remove all detachable parts so you can see the bare frame then carefully watch how each part moves as you try to close it. It could be something bent out of shape or jammed. Silicon spray is the best lubricant to use on buggy frames.
