I dropped my E1235 on the floor at a concert, only fell a few feet as i was sitting down at the time. Since then nothing appears on the screen - it's just white. i have tried taking out the battery, turning on and off etc, and all the functions work, lens, light etc but nothing appears on the screen and I cannot view any photos. would really appreciate some help. thanks
Ok, I just solved this issue. I have had the issue for a while and called GE and they told me they would give me a discount replacement at $125, when new it is less then $100. SO GE ITS NOT HAPPENING!!! Well I decided to fix it my self.
1st: Take out all the screws (7 total) one is hidden under the av out cover. Make sure u mark all the longer screw heads and location with a marker so you know where they go. There were only to sizes so if you mark the longer ones you should be ok.
2nd slowly pull the back of the camera back (BUT BE CAREFULL, do not pull to far there are wires from the LCD and buttons to the camera.) Now there is a little tab on the main board holding the wires from the LCD to the camera. Flip it up and remove the LCD wires. After you do that push the LCD wires back in and flip the tab back down. Be careful not to damage wires or tab. Put case back together, put screws in where they go, and wallah. Your camera should work. If not try again, and make sure your properly putting wires in. If it doesn't work email me I will be making YouTube video for this soon. REMEMBER TRY AT YOUR OWN RISK!!! I AM NOT RESPONSABLE FOR ANY DAMAGE YOU CAUSE!!!
