Question about StarTech.com StarView SV431USB 4-port KVM Switch
What is the key emu when talking about starview box ?
loftys0504
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • StarTech.com Expert
  • 191 Answers
Before you can access the hidden menu for the emu you must have the latest firmware or update for your receiver if you do then scan after complete scan press menu then 1570 go down to emu turn on with left or right arrow key on remote then press exit exit back to main screen and all should be working
Posted on Apr 24, 2010
  • loftys0504 Apr 24, 2010
    basically the emu turns the signal on if the emu is not turned on all the channels will say bad or scrambled channels
Starview box Keeps Re-Booting . l recieve a
try this delete the channels all of them but do not do a factory reset manually delete turn the emu off then go back and rescan and turn the emu back on but please do factory reset the box
Apr 27, 2010 | StarTech.com StarView SV211K 2-port KVM...
I cant turn my emu on, on my starview box any ideas?
have you tried to access the menu by pressing menu then 1570 then that opens a new /hidden menu scroll to bottom and turn on emu hope this helps
Feb 27, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Starview box(3 YEAR OLD)gone off,follwed instructions to factory
1st have you scanned the correct provider ex NTL, TW etc?
2nd did the scan find any channels or none at all?
EMU is the emulation to unscramble the channels, to access this in a starview press menu enter 1570 to bring up the secret menu, scroll down to Key EMU and use the <> buttons to turn on.
Exit out and select a PPV channel eg Sky Sports 1 and it will update. You are then set to go.
If no channels are picked up with the scan then check the VM website to see if there are engineering works in the area causing the problem.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Has anyone got the code for starview box in cork
Go 2 menu installation press 1570, make sure key emu is on n key reset n exit
Jul 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview codes ntl Dublin July 09
Go 2 menu, hilight installation, press 1570, make sure key emu is on n do a key reset mine worked ok.
New codes for starview box
Go nag press 1570, make sure key emu is on n do a key reset n exit, shud go mine did.
Jul 05, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Box gone off
Do an AUTOMATIC SCAN. but to make sure you get ALL the channels you need to have KEY EMU turned on. To turn KEY EMU on, press MENU, PARENTAL CONTROL, then on the remote press "INFO" "2004" Go down to KEY EMU and make sure it's on. If you press enter on NAGRAVISION this is where you enter the new keys. So choose TW, Key 0 AA B7 D1 D9 CE 8E 83 AF then press "OK" to save. Now change Key to 01 and enter 8E 80 D7 EF 44 93 02 2B Folllow all that and you should be OK
Jun 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
Please new codes for starview box may 2009 the box/starview codes for ireland dublin chorus ntl no sports or movies working
first upate it from your pc with firmware v3.00 second press menu then type 1570 or what ever your number is to get into nagravision then go to SET DEFAULT KEY PRESS OK TURN ON KEY EMU .now exit back to tv it should say channel updating when it gets to %100
May 27, 2009 | StarTech.com StarView SV211K 2-port KVM...
Ntl codes for starview feb 09
Hi, check your keys are stored, make sure emu, is on, the codes have not changed, the problem is at your end.
Feb 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Emu
hi press menu then key in 1570 another menu will come up and that is where the emu is good luck
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV431USB 4-port KVM Switch Logo
152 people viewed this question
Top StarTech.com Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
