You didn't state whether it's a top or front loader. either way, there's a switch activated when the door is closed and washer is in cycle mode- so you can't open the door when a. the front loader has water in it, or b. the top loader is in agitate, or spin cycle. if top loader- there's a tab on the end opposite the hinge side that activates a switch that latches the cover closed when in 'dangerous' cycles (don't want to get your hand caught in the spin cycle!!). either a loose wire or a failed switch! prob. need to gently pop the top (should hinge back) to access the switch. UNPLUG THE WASHER!! if a a loose wire, re-attach-if not, replace switch! easy! good luck!
Thank you for contacting
fixya.com.
You did not mention the
type and the brand of your washing machine. However given bellow are some
options you can try.
Whirlpool Duet Dryer -
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
In Hoover washing
machine try holding down the temperature and eco/rapid options together to turn
off child lock. Some series use "TEMP and OPTION" at the same time.
Please get back to us if you have further query else please accept the
suggestion.
