Question about Bosch PCK755UC 30 in. Gas Cooktop
Can i install bosch cooktop in a 26-1/2 by 19-1/2
Can i install a Bosch cooktop in a 26-1/2 by 19-1/4 cutout in granite counter top when the cooktop says it should be 22" by 19-1/4"cutout?
Posted by mrgoat on
Jyackle5
  • 8,197 Answers
No you will not be able to put in that cut out. The reason why is you will have 2 inches on each side or 4 inches on one side.
Posted on Apr 17, 2010
I have a Bosch model 8054 gas cooktop and the decals under the knobs are worn away, any ideas for replacements , called Bosch. They said they don't have replacement decals
Hello -
I found some suggestions in an answer to a similar question for a different make of gas cook top. One of the suggestions here may be one you would wish to follow:
http://forums.whirlpool.net.au/archive/1772463
Best wishes.
Jan 11, 2018 | Bosch Cooktops
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
[email protected]
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
I just bought a 7904427 electric kenmore cooktop, which isnt installed flashed to the countertop, there is 2 mm gap between countertop and cooktop, cooktop sits on the 8 brackets instead of the flat...
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - [email protected] - http://.www.StoneRepairman.com
Jan 09, 2011 | Kenmore 30 in. 42701 / 42702 / 42709...
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
My bosch gas top spark lighter doesn't work on any burner...how do I fix it?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 21, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Aug 07, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
Dec 03, 2008 | Bosch 36 in. NIT8653UC Electric Cooktop
Removing and reinstalling
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
Apr 07, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Bosch PCK755UC 30 in. Gas Cooktop Logo
294 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
mpservices
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
