Question about Refrigerators
The light in the freezer and infrared light for the icemaker does not work. Tried replacing bulb, but still did not work.
Posted by dausterlitz on
John Street
    Guru:
  • 513 Answers
The light is controlled by a door switch. Look for a button or lever where the door can strike it. Try gently pulling on the switch while the door is open. If the light flickers, you need a door switch. If not, it likely is still the door switch. They are not expensive but can be tough to change, depends on the model.The light in the freezer and infrared light for - adec639.jpg
The switch will mount a bit like this. May have a lever or a plastic pin on top. Can be round. The fingers hold the switch into the panel. These fingers need to be compressed to the body to get the switch out.
Posted on Apr 17, 2010
Ge tfx22kr
Have you checked the light switch. It is common for the light switch to also keep the icemaker from driving the ice through the door. It shouldn't keep the icemaker from making ice though. It could be the icemaker being bad or the water valve being bad.
Aug 17, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool side by side has an infra-red icemaker control across the opening just bellow the icemaker in freezer compartment, what does this do and what symptom if it were faulty? The icemaker makes ice...
The mechanical shutoff arm on the older ice
makers has been replaced with an electronic
ice level control system. This system is located
on either side of the freezer liner and utilizes
infrared light technology to sense the level of
ice in the door-mounted ice container.
Diagnostic and pretty pictures are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Used to make several batches of ice a day, now 1-2 a week.
If your refrig has the icebucket on the door and the icemaker on the roof of the fridge then you have two eyes on each side of the freezer....they are bad. If not then the icemaker module is bad. If you have a regular icemaker that hangs from the left side of the freezer then the module is bad. Also......Is your freezer still working good? Icemakers will not work if the temp is not low enough. Are you sure the icemaker is cycling but not making the full number of cubes? Low water pressure will force the icemaker to make only a few cubes at a time
Sep 11, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | Whirlpool Refrigerators
I have a Whirlpool side by side fridge, model GC3PHEXNS02. The icemaker stopped working one week ago. I just replaced the dual water inlet valves, but the icemaker is still not working. The infrared switch...
The general rule is to put 2/3 cup of water into icemaker , and if it dumps , but doesn't fill , replace the water inlet valve . If it doesn't dump , replace the icemaker Pt # 2198597 . Check the black fill tube above the icemaker fill cup , to see if it is clogged with ice . The fill line runs from the back of the refrig , between the liner and cabinet ( unaccessable ) , and down to the icemaker . Some of this model refrig , come with a coupling on the back , which you can disconnect and blow thru , to see if it is clear to the icemaker . If you do not have a coupling , you may want to aquire one Pt # 4211117 , in case this happens again , also , turn your freezer control down slightly , it will be a quick troubleshoot step . It sounds like the optics are ok , but I'll still give you the information .
Open the freezer door and if you get 2 pulses followed by a pause repeatedly , press in on the left side flapper door and the optic should stay on steadily . If you still get the 2 pulse and pause , then the optics are faulty . If you get no light , the icemaker is in the harvest mode ,( trying to dump ice ) . If the icemaker arm is in the normal position and no light , the optics are faulty . When the optics are faulty , replace both sides , the emiter board and reciever board . They come togather in a kit Pt # 4389102 .
Aug 29, 2009 | Whirlpool Refrigerators
Icemaker
you may have a clogged water line going to the ice/water dispensor
Aug 24, 2008 | KitchenAid KSRG22FK Side by Side...
Ice Maker
the LED's are optics they sense the level of the ice in the bucket on the door under the icemaker is 2 1/4" screws you can remove the IM and the white cover put a small jumper in the pins T and H this will cycle the IM the door and optices will need to be closed (or best to tape them so you can leave the door open the IM should cycle if nt check the power at the N and L pins see if you have 120vs then we can go from there
Apr 08, 2008 | Freezers
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
