Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
Posted on Apr 16, 2010
Need manual for pioneer deh 3750mp setting the clock
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
993
Points
Turn the power off, and press 'clock' for display. Then press 'audio' for a few seconds until the numbers on the screen started to blink. Set the time using the arrow keys.
How to set clock on a pioneer car radio mosfet 50wx4
Mosfet 50wx4 indicates a feature of the Pioneer car radio. It isn't a model number. One Pioneer car radio/CD player with this feature is the DEH-1500. On this model, you need to turn off the unit to set the clock. Press and hold the Source button (to the left of the preset tuning buttons) until the device turns off. Press Audio (upper right corner) repeatedly until the clock appears in the display. Use the arrow keys (Skip/Back or Left/Right) on the right hand side of the radio to select a segment of the time to adjust. Use the Up/Down arrows to set the current time. Repeat choosing the time segment and adjusting the time until both the hour and minutes are correct. Press Band or press and hold the Audio button to exit the clock setting mode.
ManualsLib has the manual for the Pioneer DEH-1500 here: https://www.manualslib.com/products/Pioneer-Deh-1500-Car-Cd-Player-Mosfet-50wx4-Super-Tuner-3-Am-Fm-Radio-3432555.html . See page 16 for the clock setting procedure: https://www.manualslib.com/manual/129844/Pioneer-Deh-1500.html?page=16#manual . See page 6 for the picture of the front-panel buttons for the DEH-1500.
I hope this helps. Please add a comment with the model of the car radio if the above procedure doesn't work for your unit.
How do I set the time on my pioneer DH3700 MP car radio ?
I can't find a DH-3700MP on any Pioneer Electronics site. I did find a DEH-3700MP, https://www.pioneer-car.eu/dk/en/products/deh-3700mp/support .However, this model doesn't have a clock.
There is also the DEH-P3700MP, https://www.crutchfield.com/S-pFBTooZ0OGM/p_130DEHP370/Pioneer-DEH-P3700MP.html . Setting the clock is shown on page 34 of the manual, https://pdf.crutchfieldonline.com/ImageBank/v20070116102800/Manuals/130/130DEHP370.PDF . To set the clock, press Function repeatedly until the clock appears in the display. Use the left/right arrows to select either the hours or the minutes. Use the up/down arrows to reach the current time.
I hope this helps.
Can i convert pioneer DEH 3750MP car CDplayer for USB pendrive input?
Download the user manual to your car player, and see whether it can possible. To download it, click here. It is a tricky free site indeed.
9helpful
How do i adjust the clock on a deh 1900 mp audio
ive had a search for you and found the manual to download for your pioneer,
hope it helps you set the clock
http://www.retrevo.com/support/Pioneer-DEH-1900mp-Car-Receivers-manual/id/23227bh432/t/2/
1helpful
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
4helpful
How to set clock on deh p630p630
go to pioneers website and look up the manual for your deck scan through it until you find the info you need
7helpful
Changing the clock on a pioneer p5100ub?
Look on page 28 under Adjusting Inital Settings to select Clock in the inital settings. Now reference page 29, item number 2 to complete clock setting.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-P5100UB_OperationManual1208.pdf
1helpful
2answers
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
