The only way I can get it to boot is to do a system recovery which lost all my stuff and every time it turns off I have to run the rcovery again. I tried to run a virus scan but it wants to turn it self off and then I have to run rcovery again.
If you still have an installation disk, put it in, restart, and run a startup repair. if that doesn't work, try to do a system restore. if that doesn't do anything you'll have to completely re-install windows.
It should still be fixable with a disk.
If you still have warranty on it, you can ask the manufacturer for a solution.
If not, and you're okay with doing something technically illegal. but still morally okay, you can download an installation disk.
I would recommend bittorrent. First, go tohttp://www.utorrent.com download and install, then go tohttp://isohunt.com and do a search for your current version of windows. Burn it to a CD then boot off of that, and re-installing should be pretty straightforward from there.
Sounds like a bad hard drive. Suggest downloading Spinrite 6 from www.grc.com and creating a boot CD. Boot with the CD and run to diagnose the hard drive.
Switch ON the PC, boot the PC in
'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System
Restore
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select the first date that you see in Bold.
The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
If you feel that my answers have helped you getting
solution to your problems then please give a vote.
Thanks.
Compaq Presario doesn't come with installation disks. We've done the system restore but it requires a restart and we are back to square one. How do we re-install Windows?
