Question about Mintek MDP-1810 Portable DVD Player
Battery not taking charge - Mintek MDP-1810 Portable DVD Player
Oyelade Gbenga
  • 713 Answers
Hi,if the battery of your portable dvd is no longer taking a charge it means the cells within the battery are dead which means the battery needs to be replaced,i will suggest you contact an authorised dealer to purchase the battery,please ensure you buy from an authorised dealer,so you don't buy a substandard battery. please don't forget to rate this solution positively.
Thanks and take care
Posted on Apr 16, 2010
Testimonial: "Thank you .. as I suspected"
Anonymous
    Novelist:
  • 144 Answers
The rechargeable batteries have a limited lifetime. They will deliver a progressively shorter operating time as they wear out. Your best bet is to replace the rechargeable battery.
Testimonial: "Thank you .. that is what I suspected"
New batteries but it keeps saying my batteries are low and just keeps beeping.. have bought new charger base as well
-New batteries... that's right. but does it take charge..? If not then
nothing.
-When it's ***** then take the battery out and measure in DC Volts. (Write it down)
-Now charge it for couple hours and take it out and measure again. If there is some voltage then it's okay. but if there is same
voltage before charge then the battery does not take the charge or may be the charge can't charge.
Good luck
Mai
Jun 12, 2018 | Cameras
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
Why does my 18v battery only take 1/2 charge?
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 25, 2011 | Milwaukee Tool V18 Battery
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    How long to charge the ipod to your computer?
    Fully charging the battery takes about 4 hours. You can also fast-charge the battery to 80 percent capacity in 1 hour (2 hours for iPod (Click Wheel)). Charging the battery may take longer if you're using iPod as it charges.
    Mar 09, 2011 | Audio Players & Recorders
    I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
    It takes over 7 hours to charge, so did you leave it charge overnight?
    But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
    The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
    Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
    http://www.bobatkins.com/photography/digital/hp707.html
    Aug 08, 2010 | HP Photosmart R707 Digital Camera
    Cant charge battery, battery wont charge
    Hello. When a battery will not take a charge do the following
    1. remove the battery and take it to any autoparts store to have it tested. If is ok great. If not replace it. joe
    PS if the battery is good the only cause of not charging must be a faulty charging system in the scooter. Joe
    Mar 27, 2010 | Health & Beauty
    How long does it take to charge metz 45-50 battery
    it will take 4 to5 hr to charge the neon will be bright when the battery are weak the neon will be Dim when the battery are charge
    Oct 27, 2009 | Metz 45 CL-1 Flash
    How long does it take to charge batteries?
    depending on the type of battery and charger the time usually takes from 6 to 12 hrs. for a full charge. Shorter charging time will result in battery not operating to its full potential
    Aug 12, 2009 | Universal Battery Charger Charges Multiple...
    Mintek MDP-1810 Portable DVD Player Logo
    451 people viewed this question
    Top Mintek Televison & Video Experts
    Lee Hodgson
    Lee Hodgson
    Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
